Nylon washer for 50mm pipe
Milzy
My washer has perished in my speed fit under the bath. The plastic pipe is 50mm. It’s one of those thin nylon brown rings.
I had spares but seem to have gone missing.
I’m just trying to make sure I don’t have a leak and not trolling.
Where can I order one from? This would make a good dull man club post.
PeteXXX
Photo Winner
Hamtun
Screwfix? Toolstation? 🤔
glasgowcyclist
Charming but somewhat feckless
Scotland
When mine perished I couldn’t find one in any of the retail plumbing supply shops (B&Q etc) and found a trade supplier in a nearby industrial estate.
He sold them in packs of 20 and when I told him not to bother as I only needed one, he burst the pack and said I could take it - free!
Milzy
Milzy
largest i've got is 45mm diameter... from a bag of 50 random washers i got from a pound shop years ago, which had every size apart from the size i needed :sad:
I bet the internal is 45mm. Had spares I found a month ago but either threw them out or put them somewhere I can’t find.
Milzy
Milzy
more than happy to post it to you if it's the washer you need. I'll post a picture on a ruler when i get chance.
You never know. Mines an elliptical shape now. If not I’ll find a spare somewhere, luckily got an en-suite.
newts
Isca Dumnoniorum
CXRAndy
Lincs
The nylon ring is usually a backer washer for the rubber washer in front.
50mm waste outlet from bath is slightly unusual. 40mm is the norm, but if you have a long pipe run to outside then regs require 50mm.
I don't like push fit under bathroom units or behind walls, it will always leak at some point. I solvent weld and fit strategic access for cleaning out welded pipes in the future. If do need to have a slip joint it's always a female socket in a vertical position, so reduce possibilities of leaks
Milzy
Milzy
Don’t know why the old owner put a slip joint there behind tiles. Which way around does the black rubber cone seal go? With the narrow at the front and wider at the back?
Fastpedaller
Just as a 'little nugget' ..... It's always worth trying the fit or parts before leaving the shop (though of course not possible if half of it is attached to a pipe at home!). I bought a 40mm straight compression connector from a builder's merchant and it all looked fine until it was connected to a pipe, and the nut wouldn't fit over the rubber tapered washer. It transpired that all the rubber washers were too thick - the nut would only fit over the washer without the pipe in place. Not much use if you want to connect pipes together :laugh:
Milzy
Milzy
I’ve just tried it without the Nylon but as said it keeps the black rubber cone one in the correct place. I tried with half a cup and it leaked. I just can’t believe there’s a slide on after a small trap. The black line is where the slip joint is.
