GrahamNR17
- Norfolk, UK
Do any of you know of anyone making old fashioned cycle lamps, but with modern (LED?) internal gubbins? I ask as I've just put a set of LED lamps on the old Raleigh, and it looks really pants
GrahamNR17 said:Been thinking that too. I tried to follow the thread on making your own LED lights, but my brain started going all misty at the talk of "LED drivers" and things. maybe I'll re-read that thread a few more times and see if I can come up with something![]()
Been thinking along them lines too, but I'm a bloke and I was thinking of something else at the same time, and we just don't do 'thinking of two things at the same time'Arch said:Looking at the lights in that pic you posted, I'm sure you could make something up, even if you just found a way of slipping a cheapish LED light inside the old bulb housing (might have to cut the old housing out). The main thing I suppose is being able to operate the switch and get to the batteries when you need to.
Arch said:Out with mates last night and we got talking about the old acetylene lamps that used to hang from the hub of a penny farthing - they hung on a pivot so that they always hung down, and cast their light through the spokes and rim. My friend mused on whether any eegit ever thought "That needs tightening up!" and ended up with a lamp spraying lit acetylene in an arc as the wheel span....
"I say, old chap, do you know your hat's on fire...?"
Superb, just ordered a couple, that's the back light sortedBokonon said:SJS sell LED replacements for standard push fit and screw fit bulbs, but only in red (so rear light only) and rated at 3V for battery use.
Creating a white LED replacement for battery use would be trivial, as simple as an LED and a resistor if the polarity of the fitting is known. Replacements for a dynamo system, however, would neccesitate a much more complicated power conditioning system.
GrahamNR17 said:Yeah, D cells and they weigh a ton (like it matters on a bike that heavy) but I have those adaptors, it's like a hollow D cell that takes an AA size.
Just hitting ebay for a suitable front light - and I can't find one![]()
