Part needed
HOU5EY
I need to get hold of a spacer to go on the bottom bracket so that my crankset sit slightly further out as my front mech can't quite get down to the bottom cog. Is there such a thing and what's it called as I can't find anything online. Thanks
dave pp
Fitted a new shimano deore bb on my mountain bike last year and there were spacers included with that, 1mm (x2) and 3.5mm Just google shimano bb spacer or try sjs cycles.
H
HOU5EY
With the new crankset the small cog is only about 2mm away from the back forks and the mech doesn't drop down that far. I need a spacer between the frame and the crankset
Citius
That looks like an internal/square taper BB, which means that fitting a spacer is not an option. You need a BB with a longer axle. Whatever chainset you have should also tell you somewhere what length BB you need.
H
HOU5EY
If I get a bb with a longer axle will that not just be longer on the outside? My mech won't go in far enough so I was thinking that the crankset needs to come out further?
