FishFright
More wheels than sense
I'm sure the CO2 thingy wotsits work perfectly fine but I just can't face the waste.
Don't be ridiculous.Why not just resolve the helmet debate as well?
You remember Lauren Bacall in To Have and Have Not? Like that.If you carry only Co2 how do you get the tube "started" so it doesn't get trapped under the bead?
Is that the unscrewing of the valve core? So far so good. Did the Road Drive have a pressure release button on it like the current crop?I own three of its predecessor\sibling the Road Drive. They have their flaws when used with certain types of tube.
I couldn't be bothered fiddling with the pump the other day so started mine by blowing it up with my mouth a bit. It was a forgiving tyre thoughIf you carry only Co2 how do you get the tube "started" so it doesn't get trapped under the bead? Or is we all tubeless these days?
I just thought that was ordinary, Co2 I only consider a one day remedy, nitrogen would be a better choice than clear air.Has anyone else had problems with Co2 permeating through the rubber of inner tube ?
When I used Co2 - I would find myself having to add more air with a pump, the next day or so after
Perfectly normal. Tubes are much more permeable to CO2 than air.Has anyone else had problems with Co2 permeating through the rubber of inner tube ?
