Really Steep Hills - What's the point?
Bill Gates
West Sussex
I can see that for some cyclists there is the challenge of getting up a really steep hill without climbing off and walking. However the lightest rider in a group will nearly always get to the top first so few surprises there.
You can put the same amount of power down on the flat for longer if you want, so if the challenge doesn't do it for you (like me), then where is the training advantage?
ttcycle
Cycling Excusiast
ah but Bill, the short answer is it trains different energy systems when going up a hill rather than being on the flat and can be great for muscular endurance and building that up.
Plus, not always is it a case of the lightest getting to the top the quickest.
Brahan
West Sussex
Maybe if there are two riders of equal weight and power who are facing each other in a race sutuation then perhaps the one who has more hours of climbing under their belt would have a greater chance of coming out on top. Maybe their technique could be better?
From a personal point of view - I couldn't even climb Kidd's Hill on my compact geared bike last year, so my first challenge was to ride to the top of it without getting off. Happily I managed it. :biggrin:
I am Spartacus
N Staffs
Maybe silly 30%ers are best avoided... but who wants to be 1 dimensional either?
You are going to come unstuck in a lumpy 50mile road race if your body hasnt been prepped for hill strategies.
MacB
the problem for me is the downhills that always accompany them, cowardice or whatever, but I just don't enjoy them that much. I certainly wouldn't want to ride a hilly area all the time, I enjoy tooling along on a rolling landscape more than anything else.
ttcycle
Cycling Excusiast
Ahh really?
I struggle up hills (and I am pretty light) but do it for the training and also for that wonderful downhill bit where the road is clear and you can zip down it super fast.:biggrin:
MacB
ttcycle said:
Ahh really?
well being hefty I can freewheel/pedal at quite alarmingly high speeds downhill, but only on roads I know very well. The rest of the time I'm more concerned about my brake pads and the amount of heat going into the rims.
ttcycle
Cycling Excusiast
MacB- let go and see where the wheels take you. I understand if it's a busy road then fair enough there is no point tearing down it but letting go of that control can be fantastically rewarding in some situations.
ttcycle
Cycling Excusiast
spartacus, when things go up, they must by nature of physics come back down again;)
PS I am not a lad...!
jimboalee
Solihull
If a cyclist's flat road powerMax is 375 Watts, that will equate to approx 40 kmh round a track.
Boardman's hour record was about 450 Watts.
That kind of power is exerted on a hill, but in a gear that is low down the range on the bike.
To sustain 450 Watts round the track emulating Chris, the cyclist would need something like a 140" gear, 57T to 11T setup at 85 cadence, or 55 ring and 11 sprocket at 88 cadence.
[I have seen this. When Chris did wind tunnel tests at MIRA.]
For the likes of me, to get 375 Watts of power output but with 60 cadence on an everyday roadrace bike, I'll need a 59 tooth chainring to whip along at 40 kmh.
On steep hills, rolling the pedals round at 60 cadence doing 6 mph, requires 375 Watts but without needing a 59 tooth chainring.
MacB
thank goodness for that, there was me worried it all might be a bit complicated, that clears things up nicely:biggrin:
GrasB
Nr Cambridge
It's a about coping with high load conditions, it turns out I'm damn good at climbing compared to most people & often will turn around & do the longer climbs around here in the middle of a ride just to get more climbing in. The net result is I seem to be able to power though head winds & deal more easily with heavy loads.
+1 at the best part of 13st I'm not exactly the lightest lad about, however I'm quite often one of the first to the top.
ttcycle
Cycling Excusiast
+1
It's also about training your body to work harder and do it more efficiently..plus, it also trains up the lactate threshold ie the zone where you feel as if your legs are aching like mad and you're sucking in the air like there's no tommorow - so you can push harder and be more efficient before you get to your lactate threshold- this is essential for races etc. You can only train that system by pushing yourself hard enough and that for me is going up and down some hills...still not seeing too much improvement myself...lol
Bill Gates
Bill Gates
West Sussex
Back in the days when I was winning races, invariably I went comparatively better on those days that were harder (windier, tougher courses etc.). I put that down to upper body strength and sheer bloodymindedness. I won a championship 25 on a day when the trees were bent over double in a gale.
However I never ever sought out any steep hills to climb in training as I couldn't see what good it would do me. Of course I trained on hills and have even won hilly time trials so it's not as though I couldn't climb. I did do our club hill climb one year and came 2nd. The winner weighed about 65kgs and to my knowledge never did any other form of racing.
Straining to get up a steep hill @ less than 40 rpm is not for me.
