Daninplymouth
Hi, been playing around with my rear wheel then noticed my gearing was a bit off. Does my derailleur look bent? If so which way do I need to adjust it?
It’s not so much the adjustment as the bike was running perfect. I was then playing around moving the rear derailleur as I just got a chainlift tool however it wasn’t set up right at first. Then after I noticed I had lost the ability to get to the smallest gear, I could get on it using the di2 trim adjust but had to make a large change. So was wondering if I had bent the hanger slightly whilst getting used to the toolAdjustment guide and video here is a good resource
https://www.parktool.com/blog/repair-help/rear-derailleur-adjustment
Is this the tool you haven't been able to do without? Maybe return the RD to the position before you started 'playing around'.I was then playing around moving the rear derailleur as I just got a chainlift tool however it wasn’t set up right at first. Then after
That’s the one yes chainlift. I was playing around removing the wheel and swapping to the trainer quite a few times so I could have knocked it on this. But at first the tool wasn’t set correctly on my derailleur so wonder if I pushed it at an awkward angle. After I I had finished I noticed I couldn’t get onto my top gear and could only do so by moving the trim adjusters quite a bit which says to me something got movedIs this the tool you haven't been able to do without? Maybe return the RD to the position before you started 'playing around'.
https://eu.chainlift.com/pages/how-to-use-chainlift
Sounds to me like the derailleur hanger has been bent. A more likely scenario than the derailleur being bent in my experience.That’s the one yes chainlift. I was playing around removing the wheel and swapping to the trainer quite a few times so I could have knocked it on this. But at first the tool wasn’t set correctly on my derailleur so wonder if I pushed it at an awkward angle. After I I had finished I noticed I couldn’t get onto my top gear and could only do so by moving the trim adjusters quite a bit which says to me something got moved
It would have been set up right Iv not long had it back from being serviced and set up, this is when I took notice of what my di2 trim was -2. When I was getting to grips with the chainlift after trying a few times I realised it wasn’t pushing my derailleur straight back, have made a tweak now so it works fine but then after refitting the wheel I couldn’t get to top gear. I can now use all my gears but have set my trim to +14 so that’s quite a change so guessing something had bent something and wasn’t sure if you’d be able to tell from the photo. Will take a closer look at the hanger when later"the bike was running perfect. I was then"
Doesn't seem likely (to me) that a bent hanger would result from:
"playing around moving the rear derailleur . . . it [?] wasn’t set up right at first. ThenafterI noticed I had lost the ability to get to the smallest gear"
But this is Di2 stuff and maybe, @si_c you recognise the symptom.
I'd never heard of it either. It looks like it is just something to stop you having to manually handle the chain when removing/refitting the rear wheel.Apropos of nothing (or, considering the context, possibly everything) what the hell's a 'chainlift tool'? Never heard of this before, despite being across most cycling gadgetry. Looked at the website and I'm none the wiser.
For me - and I'm perfectly happy removing and replacing a rear wheel whilst wearing nitrile gloves - it's the same set of benefits as a chain keeper, with the added benefits of making the wheel in/out bit a little easier too. Plus, and this is a big one, it provides the ability to spin the wheel freely to listen for bearing and disc brake issues without chain / freehub noise. It's like being able to take the chain off without actually doing so. And I can see how it might be possible to bend the hanger and I'm confident I can avoid that now that I've recognised how to do it.OK - I get it now. The point's still eluding me a bit though, I have a box of nitrile gloves that cost a couple of quid & a chainkeeper bodged from an old hub & cassette, which let me do the same thing without getting my hands dirty or risking bending my rear mech.
I do like a gadget though - am I missing something?
