Recommendations for decent winter wheels
CentralCommuter
After looking at various bikes for a winter roadie for commuting, I think I'm going for the Triban 520 on the C2W scheme. I phoned Decathlon and the only wheels they had that they could put on it for me were £550. Mental!
So, if I go for the Triban at £730, what wheels would be a solid performer to put on it? What are the go to winter wheels for commuters on road bikes, if there is such a thing!
DCLane
I'd use the wheels that come with the Triban as 'winter' wheels and spend the money on a decent set. Basically they're wheels you don't mind wearing faster or getting a bit damaged.
You'll get a better set of wheels for good weather from about £250 new.
CentralCommuter
CentralCommuter
I would, but they are impossible to get the tyre off and back on in the case of a puncture. Have phoned Decathlon who said they were aware of the issue but unfortunately can't supply the bike with a different wheel. So if I want the bike, I need new wheels!
winjim
That doesn't make any sense. If that's what they've told you I would look elsewhere.
SkipdiverJohn
Deplorable Brexiteer
London
You're seriously contemplating spending £730 on a commuting hack, plus an immediate change of wheelset??. I reckon you need a reality check, not new wheels!
You're choosing to make a massive issue about possibly having to fix a puncture. Most people who want reliability, just fit a set of Marathons and if they are really belt & braces, they might go for the nuclear option of M+ and inject some sealant into the inner tube.
https://www.cyclechat.net/threads/m...lset-with-160mm-rotors-12mm-thru-axle.253247/ ?
But I’d just get the Merlin Malt for £700 with usable wheels. It’ll be cheaper as you won’t need wheels and 105 seems like expensive over kill for a bad weather commuter bike
Why not actually go to a decent Decathlon branch at a quiet time of day with your preferred tyre levers and explaining the situation, ask if you can have a go at taking the tyres off and on. I can’t imagine every wheel has the same issue. They must be getting the tyres on somehow at the factory/workshop!
JoeyB
Go on, tilt your head!
Is it disc?
I recommend Hunt X Mason 4season for winter use. I have them on my winter bike.
Dogtrousers
Lefty tighty. Get it righty.
By all means get some new wheels if you want. I always get mine built by my LBS so I can't advise on that other than to say that 105 hubs and OpenPro rims do me fine all year round.
That said, I find it hard to believe that getting the tyre off/on is as much of a problem as you think. Lots of people have Triban bikes and I've never heard of this being a big issue. Maybe try working on your technique (push the bead well down into the rim well opposite where you are putting it on) and/or try some new levers, eg a VAR lever.
BigMeatball
There's a ton of bikes out there better than the triban and with better wheels that won't give you any headaches if you get a puncture.
It's worth mentioning that we're entering that time of the year where 2020 models will likely come out or at least be announced so I would expect discounts on the 2019 models.
If you really want this bike and new wheels, discuss handbuilts with Spa. They’ll build you something strong with plenty of spokes
