Regulations on Bridleways....
Grouchfungus
Herts
Anyone know the law re. Bridleways... are you allowed to use em' legally to bike on?
No Cycling signs seem to be appearing recently. So would this likely be over zealous landowners or local council?
llanberispass
Yes you are!
marinyork
Resting in suspended Animation
Logopolis
There's no question you are. They are very variable in nature from being as good as country road quality down to horse mushed mudbaths or even subfootpath quality and very narrow.
Some landowners don't like bikes using them and will do things like padlock gates and put up signs that have no legal status.
thomas
the tank engine
Woking/Norwich
If they're official no cycling signs then you can't cycle on those ones I would imagine.
By 'official' you mean metal, put-up-by-the-council signs ?
Maybe, but it would require a local byelaw for it to be a legal restriction.
A hand-painted or even printed sign put up by a landowner isn't legal.
You should report it to your local council as they are blocking a public right of way.
Cycling is permitted on bridleways and restricted byeways, so if your OS map shows one of these (or BOAT or RUPP, on an older OS map), you can ride it there
Cubist
Still wavin'
Ovver 'thill
Unless the bridleway has been redesignated as a footpath, then the signs are optimistic at best, or at worst unlawful. Check ordnance survey maps, and make sure you have the most up to date version, but if the bridleway is a bridleway, then ignore them.
G
Grouchfungus
Herts
Thanks for the replies.
The signs look official.
Square metal prohibition type firmly screwed on.
So I'll be phoning the council tomorrow.
Bromptonaut
Rohan Man
Bugbrooke UK
Cycling is permitted on bridleways unless there is a traffic regulation order prohibiting the activity. The official cycling prohibited sign is circular with red edging (like a speed limit sign). Square signs souns a bit odd - any chance of a digital image?
thomas
the tank engine
Woking/Norwich
Is it blue? Is it square with a red box around it - those are both advisory things I think.
One other point of note is that it is conditional that the cyclist always MUST gives way to both pedestrians and Horseriders on a bridleway
02GF74
very-near said:
No racing on them either. No wonder Bonj was so upset :becool:
depends on definition of race. would you an a couple of mates hareing along constitute a race?
If you set a defined start and finish point (and have timing equipment set up), then yes it is. If not then that could be regarded with the old chestnut 'Furious cycling' under the 1872 licencing act.
The reality is that it will only become a problem if you get caught.
