Removing... et c... The final challenge: Stuck seatpost
Andy in Germany
Andy in Germany
I suggested the cola method in the workshop and my client's eyes lit up: "Does it go boom"?
I suspect the problem is corroded aluminium oxide because the post is alu and the frame is steel. When I try to look for caustic soda all I get is drain cleaner, although it does say that you shouldn't use it on aluminium pipes so I'm guessing that's the stuff.
Andy in Germany
Andy in Germany
I've used the pedal with a loose bolt method to free the chainset, a gear puller and as a final resort an angle grinder.
Success with all three methods, with the "trick" being knowing when it isn't going to work, stop and try another method. Only used an angle grinder a couple of times, but as with using any power tool, keeping an eye on what you're doing is important. Metal warms up during cutting, so might just free it enough to finish removal by one of the other methods.
I'm guessing cutting the crank at an angle reduces the risk to the chain sorry, frame....
Andy in Germany
Andy in Germany
Amazon has quite a selection of "three leg bearing pullers" or "three jaw gear extractors" etc.
This listing has various sizes that start at £7.55. I have no idea if any of them is suitable, but they look a bit like the one in the video
https://www.amazon.co.uk/dp/B01AGKYL30
I'll measure the crank tomorrow and look for the correct size
We've now found that the bottom bracket, a nasty plastic thing, is also rusted solid. It's not a sealed cartridge, so I'm guessing I can drill into it and break it up that way, although one of my more enthusiastic clients claims to have used a blowtorch in the past: melt both sides and hammer the axle through...
classic33
Leg End Member
I'm guessing cutting the crank at an angle reduces the risk to the chain.
Why is the chain a problem if you're cutting the cranks.
I've put the one cut on the top, inbetween the arms, then tapped it with a hammer and chisel to finish the cut, and widen the gap to get it off the spindle.
What size angle grinder are you planning on using?
classic33
Leg End Member
Give him the job of cleaning the threads for the replacement then.
Is this the same client who wanted to know "Does it go boom"?
  • Like
Reactions: C R
Another vote for a bearing puller. The one I have came from Halfords, and can be built with two or three legs. Most cranks come off with three legs, but the odd one has chain-ring mounts or whatever in awkward places, so that you can only get two in - because of course the centre mount for two legs puts them at 180 degrees, whereas three legs are spaced at 120.
But make sure in Space first
Minor point, but valid.
Cycling Badger
This is what I used - available from other sellers.
B&Q Max Strength Caustic Soda Crystals
This is really not nice stuff and very much encourage anyone using it to read instructions and take safety precautions - including protective eyewear. Never pour crystals into hot water - its an exothermic reaction and can result in solution boiling and “erupting”. Hence my suggestion as a plan of last resort.
C R
Worcester
It is really dangerous stuff.
Andy in Germany
Andy in Germany
I've found some that is sold in liquid form as drain cleaner which seems the safest option. I'll try the cheap cola first, and then get properly set up before pouring drain cleaner into the frame: It seems as @Cycling Badger said, the aluminium seat post is corroded into the steel of the frame.
I'm not worried about paint as I have to respray the entire bike anyway, and we have the necessary safety equipment at work.
I'm not in a hurry as I need to remove the BB first.
Andy in Germany
Andy in Germany
Still working backwards: does anyone have an alternative to a blowtorch to remove a cheap and nasty plastic cup-and-cone bottom bracket?attempts to remove it conventionally just broke the plastic (and yes, I was turning it the right way).
Andy in Germany
Andy in Germany
Some research has revealed that Würth make a drain cleaner which uses Potassium Hydroxide, which apparently has the same effect on aluminium, so I now have a source if/when all other alternatives fail (and I've got the BB our of the frame)
Punkawallah
Can testify that caustic soda will dissolve an aluminium seatpost stuck in a chromoly frame.
Would not recommend as first option; but if all else fails and it’s that or bin frame I’d do it again.
We used high concentration made from crystals and repeated applications.
Frame needed some painting afterwords, despite efforts to minimise damage to paint - maybe we could have tried harder on that point.
[Before resulting to caustic soda we had tried cutting out the seatpost with vertical cuts using a hacksaw blade - this didn’t prove successful.]
If the alloy crank has bonded to steel spindle with galvanic corrosion and mechanical or less corrosive chemicals (ammonia) won’t brake bond then caustic soda may - but at the expense of the cranks. However, I think I’d rather try cutting off the crank before resorting to dissolving it.
Yup. Caustic soda is not fun. Don’t try it at home.
