- London
And best not get started on "cockpit," which always makes me think of machine guns spat from a blazing sun.
https://en.wikipedia.org/wiki/Bicycle_saddlePWNED
I suspect it was originally used ironically, but you know what happens.And best not get started on "cockpit," which always makes me think of machine guns spat from a blazing sun.
No doubt, but how do you brake/change gear without moving your hands? If you prefer them that's great but I'll stick with dropped bars for now, thanks.View attachment 389774 plenty of hand positions possible with these.
It's a very big subject.......apparently.It is a very big picture.
Jeese, didn't realise it was that big an image when I posted it! (Now edited)It is a very big picture.
Same as how you brake from the tops (without CX levers), ramps or ends on dropped bars! Step 1 is move hands to the levers...No doubt, but how do you brake/change gear without moving your hands? If you prefer them that's great but I'll stick with dropped bars for now, thanks.
Which is why riders with drop bars ride on the hoods much of the time - it allows for immediate brake operation. Riding in a group the brakes should always be covered; downhill on the drops the brakes are within finger range without "moving the hands to levers"; IME most riders don't spend much time 'on the tops', unless their bike is ill-fitting. I treat the top of my bars as just an occasional hand position to allow variety and use slightly different muscles.Same as how you brake from the tops (without CX levers), ramps or ends on dropped bars! Step 1 is move hands to the levers...
So in practice, dropped bars don't give "give so many options," except for some occasional relief, and the one most riders use (the hoods) also leaves their hands in an unnatural position, just less extreme than the usual flat bar grips.Which is why riders with drop bars ride on the hoods much of the time - it allows for immediate brake operation. Riding in a group the brakes should always be covered; downhill on the drops the brakes are within finger range without "moving the hands to levers"; IME most riders don't spend much time 'on the tops', unless their bike is ill-fitting. I treat the top of my bars as just an occasional hand position to allow variety and use slightly different muscles.
I agree, but drop bar advocates really should agree among themselves if it's the variety of hand positions or covering of brakes that's important to them!The flat bar end augmentation @snertos999 posted an image of (presumably he has not fitted these) looks very sophisticated and ideal if you want to ride relatively upright and move your hands to cover the brakes as soon as you anticipate the possibility that you'll need to brake.
Room for all kinds of bar in our cycling community: all with advantages and disadvantages which vary depending on the type of cycling one uses that bike (with its bars) for.
It's just struck me that (for me at least), drop bars offer the biggest range of hand positions - but not the best one. My single favourite hand position (on my bikes) is on the main grips of my MTB with brakes and gears in perfect digital reach.So in practice, dropped bars don't give "give so many options," except for some occasional relief, and the one most riders use (the hoods) also leaves their hands in an unnatural position, just less extreme than the usual flat bar grips.
Also, braking from the hoods is normally weaker than from the drops, so I suggest any group where hood braking suffices isn't riding ever so close and single hand braking would suffice in most cases, allowing one to alternate which hand was on the bar end.
I agree, but drop bar advocates really should agree among themselves if it's the variety of hand positions or covering of brakes that's important to them!![]()
