Seat-Stay Light Mounts
DCLane
I have Smart rear lights on each seatstay on my audax bike - no adaptor needed as the bracket tilts.
Seeing your issue foam would do it, or you'd have to make your own mount.
Sharky
Kent
It looks like the bottom of the light is already touching the seat stay, so to make it vertical, the bracket would need a fair bit of padding to push it out. This could weaken the fixings and make it prone to twisting into the spokes?
You already have two other lights on the seat post, so four may be an overkill.
If night time riding, I would recommend reflective slap bands for the ankles.
YukonBoy
The Monch
Inside my skull
It doesn’t sound like you are shopping around, but if you are, my Moon Comet X has a ‘ratchet’ system of sorts on one attachment that will allow you to set it to most angles of seat stays.
Wow it has amazing properties, it repels cars
"As well as keeping cars and other road users at bay, as they approach you from behind, the light also warns road users when cycling roundabouts and when pulling out of tight cross junctions or blind corners"
I bought the seat-pin & l/h seat-stay lights in November, & the r/h seat-stay about a month ago, so I'm not that eager to purchase replacements, unless I have to
(top Smart light is at least 10 years old)
If a bracket could be constructed, I'd mount it more firmly than the silicone band allows ('big' zip-ties/hose-clip)
Nope. 4's fine by me
'Built in' fail-safe
Yes, I have them on wrists & ankles
Bottom line, far too embarrassing being returned to work, in a 'big yellow truck'...…………………..:okay:
Co-incidence!!
I mentioned above about my considering 4 lights a 'fail-safe'
Whilst it still was illuminated, my l/h seat-stay light wasn't pulsing, or as bright, when I turned it on this morning (04:30 ish)
Thus, the 3 compensated
Oh!, & there's 4 on the front too
The blue light in the first picture had been replaced by another Cateye, like the 'near-side' light (as seen in 2nd pic)
Plus 4 'Lidl' specials on the helmet, not used since clocks went forward
London
Have always worried about seatstay mounted light getting into spokes. Anyone ever had a problem?
Paulus
Barnet,
I have no problems with seat stay mounts. Just make sure they are done up tight with either a rubber strip or insulation tape wrapped around the stay inside the clamp.
YukonBoy
The Monch
Inside my skull
Fibre flares are good on seat stays. Because the LED reflects out via a short length of fibre optic and mirrors it has a nice diffused light. So no blinding the rider behind from direct view LEDs on cheaper lights.
Good morning,
If you have a Poundland near you it may be worth buying one of their lights and seeing if you can do a bit of DIY.
The light mounting is a band than wraps around the seat stay, possibly with a bit of padding and an arm that sticks out to the side of the seat stay so that it can be rotated. The light then slides into the sticking out bit with a plastic tab on the back to locate it.
You would need to create a similar tab/cut off the Poundland light one and glue it on.
The light itself is fine for a pound but the batteries bounce out of their position when you hit a big bump and drop themselves and the red plastic lense onto the road, a strong elastic band helps to avoid this.
Bye
Ian
