Salty seadog
Space Cadet...(3rd Class...)
Right, I've been having shifting problems for a while. I can shift down the first 5 gears {from smallest Sprocket going up the block} fine by then the last 5 I have to hold the lever for a second or two to shift down and they sound a bit chatty. This is in the big ring up front. In the small ring shifting is similar except to change down I have to increase cable tension with the adjuster at the lever. Then going back sk to the big ring I have to let some tension out to quieten it down but it still behaves as described at the beginning.
New inner and outer put on a few months ago and today new chain and cassette as it was due. Also checked hanger alignment.
Still the problem is there.
This leaves me to suspect a new derailleur may be needed.
Sorry about the long post. Any thoughts appreciated.
