The fact (yes, fact) remains that no-one should be jumping red lights. You don't need evidence for that.
And so it follows that the people who do have no argument against being caught, nor the resources used, nor the resources not used on others. But that's irrelevant really, because it's pandering to the silly "look!! over there!!!" argument.
And once again you're waving a straw man in the air before beating it senseless. I've said
quite clearly that I don't approve of red light jumping, that I'm more than happy for cyclists who are caught doing so to be punished. You also know full well that the stats don't back up the claim that red light jumping by cyclists is a major cause of accidents (nor is being safer by red light jumping a valid claim), because you've been involved in debates that went on and on based on those stats. Therefore the claim that practically any other kind of law breaking that
is more directly responsible for causing harm is a more appropriate target for expending resources is valid, providing you believe that resources should be used where they can most effectively prevent harm. You do believe that, don't you?
You really need to see the bigger picture Cab. If you're going to moan about the resources used in this then you need to know what they are, in proper comparison to other resources.
No, I really don't need to know or comment on that; the fact is that with finite resources, targeting any
specifically on something that is annoying but not (demonstrably) generally harmful is inappropriate.
If there is data suggesting that there are specific locations that buck this, where RLJing cyclists
are causing harm, then the argument changes. If there is not, then this is not a good way to spend resources.
I anticipate that when you do this (as if), along with the necessary consideration of all the positives and negatives, you'll see that proportionally resources are appropriate.
You mean, I'll agree that some of a finite pool of resources should be spent on something that is not demonstrably (or even likely) going to work, that doesn't tackle a problem causing real harm, when similar policies not accompanied by any kind of public re-education have similarly not worked? I don't think so, not while other areas of police work remain so under resourced.
