deejayen
- Northern Scotland
I mainly ride recumbents nowadays, but I used to ride fixies, and found that slightly heavier then 'normal' gears suited me for most rides. I settled on 86" for most audax rides (up to 600k around the Scottish Borders), although I also geared down to 65" on really hilly rides.
I have a Moulton TSR which is currently set up as a fixie, but I'm thinking about converting it to a single speed, mainly so that someone else can ride it.
The bike doesn't have provision for a rear brake, so I'm looking at a hub with coaster brake. If I go for a pure single speed (as opposed to a 2-speed Duomatic etc) my best option seems to be the Shimano CB-E110 hub. The instructions say the smallest sprocket which can be used is 15 tooth, but it comes with a 19 tooth. The bike has a 48 tooth chainring. With 20" wheels, this gives a gear of around 47". I'm not sure if this would be too low, or if it might suit the bike just fine. I obviously wouldn't be racing - I'd probably use it for general sightseeing on nice days, or for some light touring.
If I fitted a 15-tooth sprocket, this would give around 59".
Of course, I could buy a bigger chainring, but the whole project would get quite expensive for something I might not use too much. Also, chainrings start to get as large as the bike's wheels! For example, 70x19 = 68". 70x15 = 87".
So, I'm just wondering how usable/infuriating a 47" gear might be!
