A long shot, perhaps, but had a (very quiet, but perceptible) sound of water from the rising main, which goes up the kitchen wall and through a bedroom, and on upwards.
Turns out it was a leak, under our passageway, in the pipe bringing water into the house from the street. As it was under our property, we had to pay for the repairs (480 squid). I think the rules may have changed now, and poss water board pay for repairs, not sure.
So, could it be rising main?
(I'm certainly no expert though).
So was I. A ghost did it.Yay, I was kind of right![]()
No one likes a smart arse.Yay, I was kind of right![]()
Is lead piping allowed nowadays? Just curious as I thougt it all had to be removed.
Shaun
This is surely not normal in the UK?Yebbut the bath cold tap and the house hot taps are supplied by tanks in a conventional system, the idea being that you've got a reserve in case the water goes off.
The only reserve tank for my cold water supply is on the side of a hill 3 miles away and serves as the reserve for hundreds of homes.
Apparently Thames Water would replace it for a bunch of cash, dig up the house and driveway.
Shaun
Lead pipe and solders containing lead cannot be used nowadays but repairs are ok, usually with a compression fitting. No need to panic if you still have lead pipework as the internal wall will be coated in limescale or whatever over the years so water wont actually come into contact with the lead.
or if you are a very good cable jointer and can "wipe lead " you can repair it with a bit of copper shoved up inside and then sealed properly.
not that i have ever done that on a job where an apprentice nailed a water pipe. oh no
