uclown2002
- Harrogate
Regardless, if there is ever a question posed and one of the options is a new bike then that is always the correct answer.
Think he means willy waving.....ie showing off.
And racing isn't?Why do you not try a proper race against proper racers, maybe a time trial with a number on your back. Anything else is will waving, sorry but that is just the way it is.
It is dangerous to hammer around outside of races because I don't know who you are. I don't know what you want. If you are looking for prizes, I can tell you I don't have money. But what I do have are a very particular set of skills, skills I have acquired over a very long career. Skills that make me a nightmare for people like you. If you stop fakey-racing on Strava now, that'll be the end of it. I will not look for you, I will not pursue you. But if you don't, I will look for you, I will find you, and I will kill you.Ah yeah, that makes sense - thought he meant that going quick anywhere outside a race setting was dangerous, i.e. time to wave your will!
Indeed, over my 10 mile commute my rigid mtb with semi slicks is only 3 -4 mins behind .It's less the bike, more the engine.
I have seen cyclists on hybrids and flat bars on my commute cycling faster then drop bar road bike cyclists. It's horses for courses.
I tend to ride on the road on my mtb in a very similar position, in fact writs crooked over bars in a tt position ish or on the bar ends in a similar angle.Any comparison has to be done using the same person (as in same engine). Hybrid will over a distance be slower due to rider's position providing wind resistance. The rider on drops racer has no choice but to be in a more aerodynamic position because of the drop bars. And that is exactly why the drops are there in the first place. The assumption is the bikes are identical except for the bars.
Not if your road bike bars are 420mm wide and your hybrid bars are 600mm wide, which I think are the most common sizes. If you ride with your hands in the middle of the hybrid bars, there's probably not much in it.I spend most of the time on the tops of my road bike. Does that mean I'm giving up any advantage over a hybrid?
Yeah, that's fair enough - I seem to do OK, but still get passed...mainly by serious looking folks in full lycra on road bikes.
I've been cycling a bit less than a year, so was hoping that a nippier, lighter bike would add a bit of speed to my ride.
Probably gonna get one anyway![]()
In-board bar ends is the solution.Probably notice most difference on a day like it is here at the moment. Wind is pretty fierce and it is definitely more difficult battling against it on a more upright hybrid rather than getting down on the drops and making yourself a bit more aerodynamic.
