Stupid mechanic errors you have made
Vantage
Carbon fibre... LMAO!!!
That's interesting my dad has a demoyo not a common make! I'll ask him for a picture?
Do you have a picture of it.
The camera makes it look squished and stretched a bit.
If I ever get my strength back it'd be a nice bike to choose for Colin's Cheshire rides.
Jameshow
Interesting not like his what's the name on the down tube.
I'll ask for a picture of his.
Vantage
Downtube name is Colutti. No idea what it means. The model is a Scorpione. Campag Veloce throughout except the chainset which I swapped out for a Spa. The original Campag was too high geared for me.
From the little history I've been told about on another forum, DeMayo frames are quite good.
Mines certainly no slouch.^_^
ColinJ
Puzzle game procrastinator!
I was chatting as I unfolded my Brompton, didn't quite get the handlebars in the right position as I tightened the clamp, set off, and abruptly somersaulted over the collapsing handle bars...into a perfect judo break-fall roll and stood up again!:laugh:
I once accidentally rode into a deep narrowing rut on a fast MTB descent. I couldn't escape from it and eventually the rut came to an abrupt end. The bike stopped dead, upended, and launched me forward over the bars. I landed on my feet and ran down the hill to keep my balance. I eventually came to a safe stop and trudged back up the hill to retrieve my bike!
Dogtrousers
Kilometre nibbler
Just remembered another stupid.
I was trying to get a pedal off an old Peugeot. It was one of those pedals with a hex socket in the pedal axle.
Well, you know how the left hand pedal is left hand thread. Yeah, I know that too. Clockwise to remove it. So I put the hex key in and turned clockwise. Nothing. I added some leverage, I forget how, heaved, and managed to turn the hex key into a barber's pole. Then I realised...
... I was looking at the pedal from the wrong side. I was looking at it from the inside - so I could see to insert the hex key. Clockwise, looking from the outside (pedal side) of the crank is anticlockwise looking at it from the inside.
Doh!
byegad
NE England
Carefully changing the chain on my Club Tour I measured twice and cut once, threaded in the new chain and it skipped locked and generally was useless. Looking at it I then realised that I'd ever so carefully threaded over the guard on the lower jockey wheel of the derailleur.
Next time I changed the chain, I did it again! :banghead::banghead::banghead:
Venod
Eh up
Yorkshire
You are not alone, post #31 ^
colly
Re member eR
Leeds
Last time I had the rear wheel off (last week) I didn't tighten the rear skewer properly. I found this out last weekend on a ride organised by @ColinJ .
Lots of up and correspondingly lots of fast downs. @GuyBoden was asking about my brake calipers and as I looked at it and put my hand on the wheel, it moved. Not just a little bit either:eek:.
I had been fiddling with the derailleur for the past 20 miles because the indexing seemed out. I found out why.
ColinJ
I just put a new sealed bearing in the freehub of my turbo trainer bike. I clumsily overtightened the nuts when reassembling the hub. The wheel span fine when the quick release skewer was undone, but when I tightened it there was some noise and quite a bit of friction from the bearings. It only took a very slight loosening of the nuts to sort the problem out. (There was still no significant play in the hub after that.)
Dogtrousers
Kilometre nibbler
Sorry Colin, but slightly overtightening a bolt is not stupid enough. You need to try much harder, maybe put a teabag in the freehub and pour boiling water over the bearings in a mug. That kind of thing.
ColinJ
Ok...
The previous time I did a job like that involved tapping out knackered bearings and very carefully tapping in the new ones (I don't have the right tools to do it properly).
I had just finished and put the wheel back on the bike when I spotted a rather important spacer left sitting on my table! That spacer is supposed to sit on the axle between two sealed bearings so they can push against each other.
I had to tap out a brand new bearing without damaging it, insert the spacer, and then tap the bearing back in. I fully expected to damage the bearing doing that but somehow managed to do it successfully.
I suppose it would have been a better 'stupid mechanic error' if I actually had killed the bearing doing that! :laugh:
