- The TerrorVortex
PimpThatSnack.com has some heroic "Mother Of All Jaffa Cake" projects
And a KitKat the size of a paving slab.
*drools*
*drools*
Landslide said:Who cares about possible trademark infringement??? Are there any left?![]()
. You'd better take them off my hands as I'm starting to feel rather sick. I just can't resist them
tdr1nka said:Our protest made it onto the 10 o'clock national news as well!
One more cuppa, then bed.
Arch said:And....
I'm asking here so as not to get laughed at. If I have a 7spd block on the Galaxy, of unknown origin, will any 7 spd twist shifter work with it?
Also, the same for triple chain rings... Although I find I don't have a triple in the box of bits, only a double. Think maybe the triple went on the hack, as a temporary bodge.
Uncle Phil said:As long as it's not one of the SRAM ones that only works with SRAM derailleurs, yes.
And, by the way, to add to your list of charmed parts, I have a redundant Shimano 7-speed twist shifter if you would like it (my 'bent started off as 7-speed then got upgraded to 8).
Yes again, but Shimano twist grips are indexed with exactly three stops. This means that you can't trim them to stop the chain rubbing in extremer gears.
On a seven-speed bike with long chainstays (lake a Galaxy) this might not be a problem. SRAM's twist grips for front derailleurs are more like a ratchety friction shifter, so you can trim them.
Uncle Phil said:Is it a screw-on freewheel, or is it in fact a cassette? I think seven-speed screw-on freewheels are rare, if there ever were such things (I've never seen one).
)Uncle Phil said:Nice point, doc.
Arch said:Ummmm....
I'll have to get back to you on that.
How will I know? (See, I'm such a dunce!)
I'm fairly sure the rear downtube shifter was indexed before. Almost certain.
