Night Train
Maker of Things
- Greater Manchester
I've not tried it, but you can give it a go in a hidden area to see.longers said:When I get round to giving things a sand and lick of love, I could put Tung over the Danish no problem, given that the constituents are related?
Usually with Danish Oil you would remove the finish and start again with fresh oil. For small areas you could touch up but an edge will show so you would take it back to the edge of the wood and lose the join in the physical edge where it won't show.
Straight Tung Oil is much easier, just a quick clean up of the surface and apply more oil. It is very forgiving and doesn't mind dust and bits in it as it all gets wiped off again as part of the process. Danish Oil traps dusts and stuff and doesn't let it go.
