mjr
- mostly Norfolk, sometimes Somerset
I was describing the activities, not only the press release, such as telling anyone who will listen things like "the new Highway Code will increase conflict on the road rather than reduce it" and attempting to divert effort into localised segregated facilities, which their local chapters then oppose as increasing conflict or making driving more difficult or some other motoring reason.No, it is the way you say these things, and things like describing the press release as "campaigning against" the changes when they certainly weren't doing so.
I haven't done that. I am always clear that "no lights or reflectors" make it shared-fault at best, but I will not excuse drivers hitting unlit objects because that is below the standard required by the licence.Things like putting all the blame on motorists for not seeing cyclists even when, in the dark, those cyclists are dressed in all dark clothing and no lights or reflectors.
But I do not agree that wearing dark clothing is a significant fault and I hardly need to criticise the unlit cyclists in most of these cases because there's enough of a lunch mob on here for them already. Is that really a good justification to call me "anti-motorist"? Nope.
Sorry but that is nonsense. Dipped headlights set to the recommended 1ish% declination should illuminate the road surface ahead far more than the code stopping distance at 70mph. If yours do not reach at least 100m, I suggest your vehicle is unroadworthy and should not be used at night until adjusted or repaired, which is often as simple as turning the adjuster on the back of the light while on level ground in front of a wall with a ruler.And your interpretation of "motorists should obey the law" would require that nobody ever drive more than about 30mph after dark, because dipped headlights will never fully light the road surface far enough ahead.
For example, including in their survey whether helmet and cycleway use should be made compulsory and publishing the disappointingly high levels. Why do that?I still have no idea what it is you think the IAM have put resources into that hurt cyclists either.
Are you, or have you ever been, an adherant (member, supporter or whatever they call it) of IAM of any type? No stigma if so, for more joy shall be in heaven over one sinner that repenteth, but I don't understand why you seem to trust them so utterly?
