The plane enthusiasts thread
figbat
Former slippery scientist
Mare of mine had an interesting theory. Flights UK to Aus for instance, way over 12 hours and an extraordinary amount of fuel.
So why not develop an 'aircraft' that can just make geostationary orbit...then sit wait for Aus to come to it..in 12 hours
(Not serious but....)
If it was in geostationary orbit then it would remain over its takeoff site!
Honestly, there's always someone who has to spoil everything with that "Science" stuff...
gbb
Peterborough
A distant Chipmunk today. Used to see them all the time in the 70s, living on an airbase, dad used to work on them.
Also a (I believe) NAmerican T6 Texan, often doing the rounds around here, heard but not seen. Radial.engines are quite distinct so a good chance it was him on the other side of a treeline.
gbb
Peterborough
Lots of military stuff out today..mostly herd not seen..
This morning, two Typhoons high up, too high to see. Shortly after, two A400Ms headed out easyt, a fairly common flightpath from Brize Norton.
Just now , something different sounding, turned out to be a A320, fueller perhaps, shortly after, the two A400Ms headed back....and i notice a B52 incoming, just over Mablethorpe headed west
Conrad_K
unindicted co-conspirator
AT least they made an attempt and got the front wheel off the ground
B52s don;t even try!!!
they just keep going in a straight line
Bicycle landing gear meant they couldn't 'rotate' the angle of attack for takeoff, so the USAF had special runways built (or older ones extended) to let them build up enough speed to take off in level flight. There used to be a "JATO" rocket-assisted takeoff package that could be installed to allow them to use shorter runways, but those were abandoned long ago. So it's entirely possible for a B-52 to safely land on a runway it can't then take off from.
classic33
Leg End Member
T'weren't mine but @ebikeerwidnes who's post you quoted.
DaveReading
Don't suffer fools gladly (must try harder!)
Reading, obvs
That's true of the majority of aircraft.
Though not recommended ...
