well done you
have you got fairing on or off
mine is ticking along nicely just waiting on a couple of parts then the mounting kit will be built then i just need to get the plastic sheet and try to get it formed
Ian
yes i did have the screen on, the 30+mph dissents and even the 25 ish mph runs are
Definitely more civilised, very planted less noise, the faster you go the less wind hits your face, i had next to no breeze on my chest and my legs.
i would have a go with draping the sheet over some kind of former with cloth draped over that and hot/ boiling water, i had a go with the sort of plastic i think you are using for making a hand guard, with a heat gun it was imposable to do without scorching the plastic as it is clear it shows any tiny imperfections,
the edging for the screen is redly available at any motorbike shop.
i am all hipper the, s u s p e n s e, will it work oooooooooow
also the top support can have a bungee going over the screen to help keep it in shape while heat treating it, you probably worked all that out any way but i am sat here with my brain clanging away
