That is surprising, unless you never ride at night in places without roadside lighting!
Towards the end of a recent metric century ride I cycled up the 5.5 mile climb from Mytholmroyd to Blackstone Edge. Unfortunately, it was a bit later than expected when I got there so I encountered a lot of rush hour traffic in the dark. It wasn't too bad for the lower part of the climb because there is street lighting there so cars coming the other way were generally using dipped lights and my pupils were not fully open to capture maximum light. The road over open moorland higher up was different altogether. Nearly all of the many cars coming towards me were on full beam until they got close to me, by which time they had already blinded me. Several times I nearly rode off into the ditch on my left and a couple of times I went the other way towards the middle of the narrow road. Not pleasant!
PS When I got to the top, I discovered that I had accidentally been riding with my 3W (maximum power) front light on its energy-saving setting, which probably explains why oncoming drivers had been so slow to dip for me! Mind you, if they had dipped too soon then they might have ended up in the ditch themselves, given that it was pitch black up there.
My bike's filthy because I went cycling today.
That is ABSOLUTELY incorrect!There is no such thing as "too windy", only insufficiently windproof clothing!!!
Rather than repeat myself, I'll search for a previous post of mine on the subject ... HERE IS ONE.
In the same area, wind causing problems ... (4:00 onwards)
Yes there is, and too wet and too cold. There is no activity whatever that I would do in those condirions by choice. Wuss? Too right.There is no such thing as "too windy", only insufficiently windproof clothing!!!
Put weight through your legs, not your arms. Weight through the arms risks your wrists and various other joints.(It will also be putting most of your weight on the saddle rather than sharing some of it through your arms which could could lead to a sore bum on long rides.)
If it works for you, fair enough, but I would really struggle after riding 20+ miles in that position.
Who cares what the weather is as long as you're safe, dry and warm? You don't have to cycle in spandex with no waterproofing or insulation.Yes there is, and too wet and too cold. There is no activity whatever that I would do in those condirions by choice. Wuss? Too right.
Indeed not. But waterproofing and insulation doth not necessarily the bike ride make enjoyable.Who cares what the weather is as long as you're safe, dry and warm? You don't have to cycle in spandex with no waterproofing or insulation.
The saddle looks many inches too low and if it is it will be making your cycling much harder work than it needs to be!.
