gom
- Gloucestershire
Indeed. And I’ve learned something. Always good.I guess that’s just perspective though, different strokes for different folks and all that
What would you know about it? Not a lot from what I can gather.
You can get pretty much all the benefits from tubeless by running latex tubes - almost as low rolling resistance and pretty good puncture resistance, and they're almost as light.
Don’t forget, a lot of people who run into difficulties with them, don’t come on Internet forums to cry about it.The one advantage of tubeless that you can't get from latex is the ability to run low pressures because the risk of snakebite still exists, a big part of tubeless is running lower pressures to increase the shock absorption and reduce rolling resistance, hence the MTB popularity.
I've been running tubeless on my do-it-all bike for over 2 years now, that's over 10,000km in all weathers, year round. I've got road tyres that look like inverted hedgehogs, only had to fit a worm a couple of times, although I do have one that I had to patch internally when I got home after a big glass cut, it would have been a boot job even with a tube. I like the fact that I can drop the pressures and go hammering off down bridleways etc. The only person I know in real life who's had serious troubles (although there's plenty on the tinternet who seem to struggle) with them is a chap who has a belief that tyres don't function with less than 120psi in them.
A supported rider. He might as well have gone for tubulars. And at those extreme distances, the gains / advantages of tubeless would be very welcome.I'm completely ignorant of tubeless, and I don't have any plans to try them, but I would note that Steve Abraham has just ridden 73,000 miles on tubeless.
“3000 miles over a couple of years”. With that sort of low mileage density, You’d have to be incredibly unlucky to get a significant puncture ( one that needed a roadside fix). But even then you seem to admit to having found the issue with getting them to reseat properly, without a big air shot. 38 mm tyres are practically off roaders, so they won’t be subject to the high pressures of a much thinner tyre ( which a lot of tubeless tyres will be, and where issues become more problematic).A couple of years back I fitted a pair of Specialized Trigger Pro 2Bliss tyres to my 'gravel' bike. So far they'd done about 3,000 miles, mostly on the road but a few hundred miles on towpaths. About once a year I check the sealant and remove any thorns I find in the casing (there's usually about half a dozen). I've never been stopped by (or even known about) any of the punctures (and yes, I'm using Stans Sealant, because that's what came with the wheels). Even though they're 700c 38mm they roll pretty well on the road. The only problem I've had is that, as they get older and softer they're more difficult to seat after removal. The first time they went on easily with a track pump, the second time I had to use a small, electric compressor, the last time I borrowed my neighbours car compressor.
When they eventually wear out I'll probably replace them with Schwalbe G One tyres because they're available in a 700c 30mm.
A supported rider.
Shirley that works the other way too? Lots have no issues but don't come on the internet to extol their virtues.
Ooh what happened there...oh you edited your post
I’d have said that was worthwhile, given the efforts he’s putting in.But trying to fix tubulars at the roadside is a first class PITA, he would have had to have carried another glued tub about.
don't use Stan's sealant
I didn’t realise he was completely unsupported, I thought he had a chase car with him.No, not supported. He rode solo 99% of the time. The 1% of the time he had some other riders. No support vehicle.
Not picking an argument, btw. I know nothing about tubeless, and I'm not really interested. Just throwing some potentially useful info in.
