Tyre Gauges
Discussion in 'Beginners' started by newstart159, 26 May 2008.
  1. newstart159
    newstart159 New Member
    I need a Tyre gauge to check my tyre pressure any recommendations
  2. RedBike
    RedBike New Member
    Beside the road
    A new pump with a guage on is probably the best option (because you see the pressure as you inflate the tyres)
    Failing that it seems that you can pick them up rather cheaply. (No idea of the quality)
    http://www.google.co.uk/products?hl=en&q=tyre+pressure+gauge&scoring=p
    Even the digital guages seem relatively cheap.
    http://www.google.co.uk/products?q=digital+tyre+pressure+gauge&hl=en&show=dd&scoring=p
  3. RedBike
    RedBike New Member
    Beside the road
    Forgot to add, most of these seem to be designed for car tyres. If you're using presta valves (or high pressures) there's a chance a few of these designs wont work.
  4. OP
    newstart159
    ok will bear that in mind but how do the digital gauges work?
  5. RedBike
    RedBike New Member
    Beside the road
    They'll all work differently, but basically stick em on the valve and read the number off the display?
  6. OP
    newstart159
    oh thats easy cool thatnks for the info m8
    Dismiss Notice
