Marie Attoinette Fan
Lol, just logged my rides taking away tonight's familiarisation session, tonight's commute and half of my lunchtime it almost exactly failed at 3000miles
Although I'm enjoying it (fixed), I'm a wee bit worried though that I'm starting to give-way less when I see a gap! Is that normal behaviour or should I try to nip it in the bud any tips for doing so?
None as yet, the direct transmission and momentum has allowed me to easily pull away and slow for smidsy visa but the surface has always been dry and I'm a wee bit worried in the event of a greasy surface or drive failure!Not sure you should be worried, unless you've had some close shaves ... I find it far easier to ease into spaces on fixed, less thinking, brain and legs just work together, nice and smooth.
What gearing are you using to get 30 mph downhill, am using 13 x 48 and i can't gey anywhere near that, mind you iam getting on a bit.Drive failure, I had a couple, at speed, chain coming off an causing rear wheel to lock, surprisingly easy to manage, both times it was coming downhill @ > 30. Once was because the chain was loose, once because the sprocket came unscrewed (bad maintenance, lesson learnt)
Have had a chain snap once on a climb, got pushed 10 miles home ... Nowadays I use DID or Izumi track chain and haven never had a problem.
Greasy/Icy, I prefer on the fixed, you feel and catch (or the legs do) the issue far quicker.
Of course I ride fixed most of the time, so am probably biased :-)
What gearing are you using to get 30 mph downhill, am using 13 x 48 and i can't gey anywhere near that, mind you iam getting on a bit.![]()
46 x 18 for me and I max out at 34mph (and not for long), which I think is about 170rpm. Not often though.What gearing are you using to get 30 mph downhill, am using 13 x 48 and i can't gey anywhere near that, mind you iam getting on a bit.![]()
.I don't think I've been over 25mph yet48x18 (~70") not sure I've been above 40, things start to rock a bit then, but up to that is fine, but I'm young.
