What Have You Fettled Today?
Quick chain clean on the commuter - cheated and used the 'muck off' cleaner gadget for a change. Did a decent job, hosed off, then re-lubed.
avecReynolds531
Small Island
A while back I bought some MKS Sylvan Touring Next pedals for the Trek FX Sport 6. I figured a bike like that deserved nice pedals. They were buttery smooth out of the box and they seemed really nicely finished.
So sometime later I bought some of the regular MKS Sylvan Touring pedals for the Trek District 4. Buttery smooth, these were not. So I put them on the shelf and forgot about them for a while.
In the meantime I did some reading up (mainly of the CTCCycling UK forum) and found an extra ball bearing and some extra grease would have them much improved. I can now verify this. Said pedals are now attached to this. Few jobs still to do before it's ready to ride, the most taxing of which will be trying to manufacture a bracket to fit my three blinkies on the rear rack, due to the non-round pannier rack stays.
Last night the Tarmac SL7 got a fresh waxed chain and a tweak to the saddle position before a 100km ride planned for tomorrow (Saturday).
iandg
After moving a pile of soil from one part of the garden to another I moved into the shade, tuned in to Planet Rock and started Fettling.
Fitted the skin wall WTB Byeways that came with my ebike to the Trucker plus a new multi-clip to the Rixen-Kaul bar bag QR. Fitted a wireless Sigma computer
Rando bag arrived so fitted the QR fixing to the front carrier of the Cross-Check
New stem arrived for the bike I was given (a rebadged Kinesis Racelight) so fitted the bars, saddle, cables, chain, pedals, and swapped the tyres. Just need to torc the bolts and adjust brakes and gears to get it roadworthy
Put a new 28mm wide tubeless tyre on the front of my good bike. It seated dry with the track pump forming a solid seal so there was no mess when I put sealant in. I then went to put its old 25mm wide tyre on the rear of my commuter. That was a pain though and refused to seat with either the track pump, air tank or CO2 and made a right mess. Then I realised what I probably needed to do give the rim a bit of a clean to remove sealant. After I did so I managed to get it to seat fine with a CO2 canister.
For good measure I wiped down the good bike chain etc and then applied drip wax.
Chris S
Birmingham
The alloy wheelset on my Sturmey Archer 3-speed came with a post-2000 NIG hub fitted. I got sick of it clattering along when I was coasting so I took the internals out of the shell and replaced them with some from a 1980's AW hub. It was a straightforward swap. My bike now ticks along like a Swiss watch. There seems to be less drag as well, the AW hub was a much simpler design.
Wheelspinner
Picked up a set of shorter cranks the other day, some 165mm with SRM Power Meter installed on Dura Ace 9000 series. So, today installed them on the good roadie to replace the 175's it had. Also flipped the stem back down to lower the bars a bit and see how I get on with it.
Swapped pedals on the trainer bike for a spare set of Speedplay Zero and now have to fiddle with cleat position on those shoes as it felt a little uneven left-right. Hmmm.
Dialing in the handlebar position and a few other minor items on this beast. It’s amazing how a few minor changes move a bike from an okay fit to really comfortable. Not that this thing will ever handle well off-road or anything… but it does shrug off a case of beer or a load of groceries pretty well.
ktmbiker58
Refitted the Fox 32TC forks to the Croix de Fer today since the promised local pot hole filling seems to have come to nothing ^_^ (Council spent a million quid on 500m of multi user path that doesn't go anywhere :wacko: )
Bike is in it's ultimate comfy mode - Conti GP5000 All seasons in 35mm, Fox 32TC forks, Brooks Flyer saddle - if the roads get any worse I am trading it in for a hovercraft!
Excuse the mess that is the dining room, but it's ready (the latest fleet addition).
  • Handle bars fitted.
  • Both ends of stem torqued to spec.
  • Factory grease stripped from chain and relubed.
  • Saddle position adjusted.
  • Pedals fettled and fitted.
  • BS6102/2 compliment of reflectors fitted.
  • Rotary bell added.
  • Bottle cage installed.
  • Garmin mount fitted.
  • Custom rear light bracket fabricated and fitted
Fettled a second set of MKS Sylvan Touring pedals to go on the town bike, when I find some pedal washers:
The folder also got finishing touches:
Pump and bottle cage installed. Took it for a bit of a shake down. It's a bit creaky, but I suppose they all get that way with a few miles on.
