The thing is this bike-building ‘Artiste’ is colour blind as far as his mechanical palate goes. I definitely have no Grey. It’s either Black - or it’s White. And I have absolutely zero time for just making do…..
So: those wretched Black pinch bolts, and rancid mild steel Crank bolts swapped out for some Titanium and Stainless steel accordingly:
The (Highly rated Odyssey) Springfield Brake Calipers are also slightly strange. In that each half of the caliper gets installed onto the Boss on the forks / rear stays accordingly. And pivots via a Brass ‘shim’ in the caliper. But the bolt holding them on also adjusts tension effectively. And so can never really be fully tightened. This played with my standards enormously 🤣
So armed with de-greasing supplies and a new roll of PTFE tape:
..….i took each bolt out. Cleaned up the bolt thread; and the female threaded boss. And applied 8 wraps of PTFE tape to each bolt:
Which meant each bolt could then be snugged-up to the perfect loose’ish tension - without fear of falling out or working looser 👌
**I then haphazardly slapped on a Custom made decal I had done onto the bars: without so much as measuring, lining up, marking out exactly where I wanted it or anything else 🙄
Just gotta machine up some Aluminium axle washers at work Monday, get the cables on and we’re good !
