What Have You Fettled Today?
geocycle
Put some Schwalbe G one tubeless on the elan. They are 35 mm and slightly knobbly for winter roads and give a bit more space under the guards than the 38 mm gravelkings which are fairly slick now. The gravelkings gave me lots of problems when tubeless but have been quite happy for the last 18 months with tubes in them. Also managed to repair a dented rim which had been irritating me.
Andy in Germany
This was during the week, but still...
Trying to find what is wrong with this Nexus hub...
Andy in Germany
I reckon it would work a lot better if you put all of those pieces back together! :okay:
You have come to the heart of the matter right there: when reassembled, the b*gg*r wouldn't work properly.
I'm not able to invest any more time in the thing so it had been taken over by a client, who is a former marine engineer and far more capable with these things than I will ever be.
ColinJ
Puzzle game procrastinator!
Whenever I try to fix something complicated, I always seem to find one part left over after reassembling it! :laugh:
MadMalx
I’ve been running those 35mm G-ones with mudguards this last month or so. Very happy with the grip on broken, wet roads and comfy at around 45psi. Ive been much more confident and not noticed extra drag.
geocycle
Good to hear. I was getting leaf debris gunging the mudguard on the 38mm gravelking tyres this last autumn and rear wheel slippage on leafy climbs. I’ll try them at 45 psi as you suggest, I usually head to 50 psi, so will experiment. They were quite tight to fit on the kinlin rims but perhaps as a result they jumped onto the bead first time.
Andy in Germany
I have that problem: I had to keep disassembling it to put bits in: my client, on the other hand, has found moving parts I doubt Shimano knew about, cleaned them and got them working again... This is why he's an engineer, and I'm a social worker.
Wheelspinner
Opinions sought: would you bother?
I have this CAAD 8 bike, bought used for cheap, which I've had on an indoor trainer for the last year or so and done around 4,000 km on there. The groupset is mostly old 10 speed Shimano 105 which is getting fairly tired now. Cranks have been replaced and are now decent (well, for BB30 at least.. ).
I've never liked the colour scheme and graphics on it - way too busy. I am considering stripping the frame completely and doing a respray, and perhaps building something "interesting".
Worth the effort or not? I like having a project to fettle, but been 10 years or more since I last did something like this. Not actually ridden this out on a road at all so I'm wondering if these are good enough to do up?
Punkawallah
1983 Dawes Galaxy touring bike:
Flipped the rear chip on my Revolt today and therefore moved the rear wheel back 10mm. My 45 mm Gravel Kings were a bit close to my mudguards …tons of clearance now. 👍. I am looking forward to noticing the difference in wheelbase…though I doubt I will.
avecReynolds531
Small Island
Good to be working again with this (wonderful - imho) English design success - this time a 2013 M3L.
As with an earlier 2008 M3L, started with the front wheel bearings:
checked,
dismantled,
& cleaned.
Cones, seals, bearings, axle and cups were in excellent (low mileage) condition. All put back together with plenty Miller OIls WG2. Preload was set to spin freely (like a Les Paul sustain), with the wheel join (opposite the valve) sitting at 6 o'clock when it stopped. Happy with that.
Stock Brompton tyre removed (Pedros tyre levers are fantastic),
& replaced with a new M+, which had been stored by the heating system all morning. A result - no tyre levers needed.
Lastly, wheel was trued, & set back in place after cleaning the fork, insides of a mudguard, brake blocks & caliper.
More to do.
