What Have You Fettled Today?
New disc brake pads front and back. Old ones just beyond limit of hydraulics to fully compensate. Pistons pushed back with a bit of patience. Must change earlier next time
Stop taking lessons from Silva ! Could have added a bit of cardboard behind the pad, or even a few chisels.
roubaixtuesday
self serving virtue signaller
From yesterday... noticed a flat on the commuter rear at home - the tyre was nearing the end of its life anyway so for once in my life decided to do the right thing: swap front to rear and new tyre on the front (I keep one in stock anyway).
On removing the rear, found the inner had a mahoosive hole in it and traced it to the tyre bead coming away from the tyre wall. Must have exploded sitting in the garage, much better than when riding!
They're 700x25 marathon tyres, a bit of a pig to get on. The new one needed a VAR lever, couldn't mount it without even after lubing the bead with washing up liquid.
Ordered a couple of new tyres as they were on offer, and pitched in with a couple of chains and cassettes too.
Friday 20th
I went to get my ‘Aubisque’ out of the shed this morning, for the ride to work
It just went ‘clunk’ as a flat rear tyre thumped over the threshold
“Bugger!”
No time to investigate (04:30), so a quick change & a car commute in
On getting home, it was looked at
The Marathon came off the rim far easier than expected (one tyre lever & fingers)
Nothing could be found, until l turned the tyre inside out
It was either a bit of wire, about the same thickness as a toothbrush bristle, or the tyres own casing?
I decided to boot it, so a trio of layers of gaffer tape went inside (in case it was the tyre itself)
The opportunity was also taken to clean the cassette/jockey wheels/chainrings
The chain was scrubbed in diesel, then lubed with a mix of chainsaw oil & diesel
The rear Marathon is getting past it!
If it was on a car, it’d be worth 6 points, not just the usual 3!!
Should be okay for tomorrow mornings ride in?
DCLane
I cleaned the Carrera Vengeance magnesium road bike, which is going to be put into storage as hopefully the worst of the winter weather is behind us. That'll be kept for next winter.
Then more attention turned to the Peugeot 653 that @Jameshow had delivered to me last month after @biggs682 had spotted it on Facebook in Bournemouth: that's a CC collective job in itself to obtain! The plastic FAG bottom bracket had become stuck; my university's workshop could cut metal BB crank bolt bits off with an angle grinder but couldn't force it out. Also, using a Campag BB tool a load of combined hands had got the non-driveside bottom bracket cup out using the tool, some washers, a bolt, a big chisel and an extremely large lump hammer.
The right-hand driveside was gone however. The plastic thread was broken and it had seized in with no way of turning the cup. So ... over the past few weeks, whenever I've had a bit of time, I've drilled holes into the plastic bottom bracket. However, having broken several drill bits, I needed a longer one.
Hence I sourced some extra long drill bits. Using those I've drilled holes right round the bottom bracket, then through sections of the plastic that didn't have holes in this afternoon. Then, I chiselled through sections. Finally, a large hammer forced the bottom bracket to move. That's let me get what few pieces of plastic were remaining out.
:hyper:
The frame's been cleaned and it'll be off to have the bottom bracket cups re-threaded in the workshop in the next few weeks, then I'll look to remove the zinc rust-proofing paint before deciding the next steps. No timescale, but it's a lightweight 653 frameset that should have potential.
Too sloppy to ride today so we’ll repack the coaster brake on the old CCM. If it’s anything like the rest of the bike it hasn’t been done since it left the factory in 39.
at least the tires are newer, mid fifties I think.
