What Have You Fettled Today?
Took a minute, wiped down my chain on my commuter with baby wipe, and a soft cloth after. Before dripping a drop of drip wax on each roller. I think I marginally wipe and relube than I did with lube but that's outweighed by components lasting longer, clean hands and no chain tattoo etc. The frame needs a proper clean but that'll wait until the weekend.
Elybazza61
Thursday partially done the rear dynamo cable re-route through the frame; had to add a short piece of cable so it was long enough.
Just need to finish connecting up to the cable from the mudguard.
cyberknight
greased the bearings on the commuter rear wheel which meant a lot of cursing as the loose ball bearings kept falling out as i turned the wheel trying to regrease everything and i even lost one somewhere so its a good job i kept a pot of spares .I gave the freehub a good clean and put it all back together eventually :smile:
The cassette looks a little worn but i didnt have one in stock so im am liable to run it through another month till the weather improves and next job is to clean the chain and check the wear followed by trying to sort out the seized barrel adjuster on the rear brake which looks like i will have to disconnect the cable and use a pair of pliers to get it out before lubing and reinstalling it .
cyberknight
Well that was fun as i had to use pliers to get the barrel adjuster off destroying the plastic bit in the process , luckily i had another set of the same brand brakes in stock so i pinched one off that and gave the threads a good lube which seemed to have fixed it .
Onto getting the gears to index and that has a similar issue so i will have to replace the barrel adjuster on the RD too but at least i have them working properly atm and as i suspected the chain and cassette both need replacing and i guess the large chain ring too .
This bike has had a hard life commuting in all weathers so its no surprise it needs some tlc .
C R
Worcester
A new rear mudguard in my road bike. This is the third, the previous two broke near the bridge, though the curve is smooth, so no stress as far as I can see. I now have two front bluemels spare. If this third one goes the same way I'll have to try a different model.
Need to run a slight tweak/experiment on the commuter.
It's old Deore XT and LX. 7 speed shifters running a 8 speed cassette with a sprocket removed. This means running 8 speed 3mm spacers. 7 speed is 3.1mm.
Doesnt really make any difference other than in the last but one sprocket, rough ground can bounce the chain onto the bottom sprocket. Never usually an issue, but this weeks tailwinds had me using them (only a 44T big chainring). Plan is to swap out a 3mm spacer (before last two sprockets) for a 3.5 or 3.85mm from the parts box.
Edit. Done. A 2mm and a 1.85mm spacer
fitted. Minor adjustment to mech limit.
I know that us cyclists are quite resourceful. I have two hi-viz light jackets, one of which has very billowy sleeves and so I rarely use that one for cycling. The body part is just a good fit so I thought what if I cut the sleeves off and make it into a gilet. Looking at the sleeves they are trimmed where they are attached to the body. I thought well I was going to bin it anyway so lets give it a try. Sleeves cut off and you`d never know, unless up really close that it was`nt a gilet. Job done, no more flapping material and just a good lightweight covering as an outer layer to temper the breeze. Why did I not think of doing it before ?
