smokeysmoo
- Bolton, not very far from Nob End
Your Cateye bracket needs trimmingIf you like red, black and white...I'm biased (and not because I have a white and black kitchen and a red Brita)
Nice... and looks like a good match for the kitchenIf you like red, black and white...I'm biased (and not because I have a white and black kitchen and a red Brita)
Bump... Anyone?So, assuming I go down the carbon route, which of the following would you consider is the better buy?
Giant Defy Composite 2 (2012)
Cannondale Synapse Carbon 105 (2012)
Given current sale prices, the Synapse comes in at 'only' £200 more than the Defy but I'm thinking it might be worth it for 105 (which I wanted) over SRAM Apex and the better wheels... beyond that, I don't know if there's a significant difference in the quality of the frame, or indeed the weight (difficult to find weights!)
Actually, it looks like whilst it says on the specs that the Synapse Carbon 105 has Mavic Aksium wheels, they look like Shimano RS10... are they still better than those on the Giant Defy?
Don't like the sound of thatDont know what wheels are on the giant defy comp but if they are the same as the standard mavics on the wifes ally version the spokes click where they cross on the rear wheel as it goes round, drives you insane lol
Thanks VicksterIf you want 105, presumably better to go for the Synapse, if you don't get on with Apex (which I like, as well as Tiagra) then it'll be more of a pain than changing the wheels - you can always flog the wheels to offset the cost of new ones - personally I would notice sub optimal shifting much more than the wheels!
Check the wheels and weights in the shops and have a test ride if poss? I'm guessing 105 is lighter than Apex, it is the next step up the ladder (Apex more like Tiagra, Rival more like 105 I think)
I'm thinking that's exactly what I'm going to have to do!Can't you get to an Evans to test ride the Dale and maybe an LBS to try the Giant? Pick the nicest feel?
From a fit perspective, the Synapse (aluminium) felt good in a 56cm, but so did the CAAD10 in a 54cm. I've not seen the Synapse Carbon in the flesh, but I really like how it looks! Again, I sat on the aluminium Defy in 2 shops – one said M was fine, the other said it looked a touch small and I should probably go for the M/L. The Defy 2 Composite is a very close second in the "looks" stageI have SRAM on the Pave and Tiagra on the Giant - Tiagra (and assume 105) is very easy once you've figured out which lever - brake or other - to press for which.... If I were you, I'd choose on the basis of fit, looks, even brand preference. When I got the carbon bike, I did not want an American brand, I wanted something different. I almost bought a Tiagra Bianchi and then Pearsons persuaded me to spend another £400 on the carbon
Are they both double chain rings, or is one a triple. I don't face many hills and to be honest, the big ring at the front with the 10 on the back is more than adequate. People do say a triple good if a hilly area...
