BentMikey
Rider of Seolferwulf
- South London
Bonj, your a mook.
bonj said:wider tyres on the road are unnecessary, and are the primary reason why a lot of people think they need mudguards. Thinner, slicker tyres don't get muddy water sticking to them and as such the splash-up only gets a few inches with my 25mm michelin P2Rs. 28mm with nobbles on - COURSE you're going to get muddy...It's like tying a towel round the tap when you're fixing the washer - just turn the water off
Too many people on here suffer from "I-might-go-down-a-towpath" syndrome. There's two disciplines of cycling - road cycling, and mountain biking. This happens to be a ROAD bike forum. People shouldn't try and pretend there's some middle ground to which they belong of being neither one nor the other but just a 'generic cyclist' - just admit you're a roadie and do things the roadie way. And that doesn't mean mudguards. Mudguards are old fashioned becasue they were only really necessary in olden days when there actually WAS a lot of mud on roads and lots of water aswell due to roadbuilding technology not having advanced as far as providing effective drainage.
I still get a faceful when I ride behind Baggy on account of her not having a rear flap to keep the spray arc down far enough.walker said:If you was part of a club, a majority of clubs would not let you ride in a group without guards in the winter, no matter what the weather was like
Course, that's fine - but I don't see the need to throw toys out of the pram in a huff and stamp your feet up and down having a little screaming strop like tdrinka.Chris James said:Bonj, of course you are allowed to have your opinion, but equally it is okay of other people say you are wrong (in the same way that you say they are wrong).
If about 9 people post that they recommend mudguards, then one person posts that they think mudguards are unnecessary, it doesn't take much brainpower to realise that the one and the nine aren't in agreement with each other. People who ask questions on here do so because they want advice from other people, not because they're stupid. 'Beginners' and 'newbies' are just that, beginners to cycling, it doesn't mean they're idiots and need every single thing explaining to them. If what they want to take away from a thread is the gist of the general consensus, then they don't need you to explain the fact that the minority of opinion is just that, a minority - they can see that for themselves. If what they want is a unanimous opinion, then - well, I'm sorry - they're not going to get that - and there's not much that you can do about it, short of setting up your own cycling forum called www.mudguards.co.uk where all that is ever talked about is mudguards.Chris James said:Since the OP asked about mudguards then it is only fair that others step in when they see your advice if they believe it to be wrong. Otherwise it would imply that everyone else is in agreement with you.
[/quote]Chris James said:You dislike mudguards, that's fine, but it seems to be based on your belief that they are heavy and rattle (not true).
What i don't get is, what is the advantage in trying to protect yourself from the water spraying up from the road when there is lots more water falling down as rain which is causing you to get a lot more wet than from the water sprayed up from the road anyway.Chris James said:Also, mudguards are not there to protect you from the rain (how would they do that?) but from spray that is produced as you ride across a wet road.
The need for mudguards also assumes that all the following are true:Chris James said:Your advice is only good if you only ride on days when there is no standing water / dampness on the roads. Which rules out most of the winter months. I remind you that this is the commuting forum so unless the OP is only planning on commuting on dry days then your advice is flawed.
Chris James said:As far as suddenly suggesting that the OP shouldn't get guards because no roadie uses them - well that is wrong too. Turn up on a club run without guards on a wet day and you may find yourself cycling on your own. Guards are a matter of courtesy to others who you ride with by not spraying them with crap.
yes, didn't used to be but am now.Chris James said:Also, from your previous posting history I was not aware that you were a roadie anyway.
oh keep your hair on miloat.miloat said:Bonj shut up.
