winjim
That looks like a 3300. I assume it's a short cage. Does it look like this(short cage SS)?
Or like this(long cage GS)?
Capacity is as follows:
So assuming a SS mech, you have 52-40=12 difference on the front, leaving you 29-12=17 spare to use on the rear. You can therefore use the full 11-27 range on the rear should you need to.
Shimano specs are notoriously conservative so I reckon you could probably get away with a 28 or maybe a 30.
My highest low gear is a single speed 1950s roadster with 42/18 gearing, and that's definitely *interesting*!
