- South Manchester
The campag 12 speed cassette is £300![]()
That's cheap as chips compared to Eagle XX1 / X01
Just have to wait a year for the "Trickle down..."The campag 12 speed cassette is £300![]()
I couldn’t find an Ultegra 6800 in 11-32 so had to buy a 105. Can’t wait for the next trickle down.Just have to wait a year for the "Trickle down..."
My biggest beef once the osts come down will be chain wear the.11 speeds are definitely more fragile
I guess that's the use case; a massive range with moderate steps. Ideal for a 1x set up.Look at 12 Speed Eagle cassette prices. OMG
I’d rather have a top frame with Tiagra on than a lesser frame with Dura ace on, I’ll tell you that.
Plenty of pros use 30 cassettes on the grand tours ?Why do you need a top end frame if you also need an 11-32 cassette? Kind of contradictory, as anyone truly utilising the difference between a good frame and a top end frame, are likely not to need a 32 tooth lowest gear.
Because I’m doing the Fred Whitton and a trip to the Alps. My local area I use 25t. Always better to be over geard than under geard. Even pros are using bigger sprockets in the mountains now. Why put loads of torque through your knees when you can spin to win. Grinding is slower, proved on the GCN show.Why do you need a top end frame if you also need an 11-32 cassette? Kind of contradictory, as anyone truly utilising the difference between a good frame and a top end frame, are likely not to need a 32 tooth lowest gear.
Fine, but if bikes had stayed in the twenties?
Does anyone still use Campagnolo?The campag 12 speed cassette is £300![]()
You sound like a Rapha brigade cycle snob who isn’t bad but just quite can’t cut cat 3.
Has it’s fan base. Mechanical feel, rapid thumb shifters. Not really my thing. I’d have a super record groupset for nothing though.Does anyone still use Campagnolo?
UOTE="fixedfixer, post: 5217645, member: 12286"]I still ride one. Drive chains last for years![]()
. Aye but I imagine you will have a constipated look on 25% gradient hills
Edit- When you say 1, do you mean one gear or one 7 speed triple?
Castelli is fine. Decent quality without silly prices and a few earthy club members use their kit. I can happily do many steep climbs on 25/28 but not all day long one after the other especially after 100 miles or so. Bail out gears for the win.Given you both likes for those replies, as some Pro’s do use 30’s at times. Some are Domestique’s who just want to save themselves to work hard another day. Others are able to pump out serious cadence all day long. The question is whether they also have a Compact or a Standard in conjunction.
The likes are for comparing yourselves to Pro’s btw.
Grinding vs Spinning is dependent on the rider. It depends on your legs and what your riding style is. I know an awesome rider who regularly grinds, but then can’t spin well. Powering down a climb, he couldn’t catch up with me because he said that he couldn’t spin as fast as me. He’s a way better rider than I am without question, but if he had to spin then he wouldn’t be as good as he is.
With respect to the dig about Rapha cyclists, I am a Castelli man @Milzy, at least get the brand right.![]()
