MacB
- Farnborough, Hampshire
and another for the road Morph pump, re tyres themselves I've limited experience. But I've been looking keenly at the Marathon Supreme as a contender.
rich p said:Another vote for Topeak Mini Morph. I can get up to 100 psi without too much sweat on 700 x 23s.
My tourer has 700 x 38s and I haven't had an issue with them. They're Conti something or other, very comfortable and still looking good after circa 3,500m![]()
(apart from the sidewalls being mucky these days
)Percy said:Thanks all - good to see this place is still lively (been dormant for a while).
Interesting comments - Paul Hewitt actually recommended Rigida Sputniks as an alternative this time. I think I might try them, with an XT hub again, and go for a larger tyre - 38 or maybe 42. Seven responses and no one has yet to come out with the '26" wheel is much stronger' response - I'm impressed!![]()
Seems Schwalbe tyres are still the go to for durability - I bought a set of Marathon Plus just before I left for the long tour, on the back of everyone's comments, and couldn't get them on my rims - nor could the LBS! Stuck with a set of Continental Top Tour in the end, to begin with, which were replaced with whatever was handy while I was away. Maybe I'll give Schwalbes another go.
The Sun Rhyno's were recommended to me by Hewitt at the time - he said they were the strongest on the market. Seems he was right - they're stronger than an XT Hub! But yes, that does seem to be his opinion having looked at the damage - I quote: "If (the Sun Rhyno Rim) has contributed to the hub failure, it has maybe done so due to the rigidity and weight of the rim, there is very little give in anything and the wheel would fail at the weakest point ie. in this case the hub." I'll stick an image of the hub on this post, as people seem to be interested.
Will also look at pumps - thanks for the recommendations.
.Crankarm said:Looks like a duff hub. Is it the same age as the rim? If so I would use the same rims as they are ok with a replacement new or different hub.
If you go any wider with your tyres you'll need motorbike tyres.
Plus they will unlikely fit the bike frame.
andrew_s said:I vote for a duff hub.
The only way I see that a stronger rim would give a problem is if the wheelbuilder takes advantage of the extra rim strength to tension the spokes more than he would on a normal rim. I know Jobst Brandt has recommended tensioning the spokes until the rim is about to pringle and then backing off a little, but I'd be surprised if Paul Hewitt built like that.
When a wheel is loaded, the bottom of the rim gets flattened slightly, reducing tension on the lower spokes. The top spokes are under the same tension as they were in the unloaded wheel, and it's the difference in tension that supports the load. Note that loading the wheel reduces spoke tension.
If the rim is a flexible one, it will only be the tension on the spokes within a couple of inches of the bottom that changes. If the rim is a stiff one, spokes further from the bottom will have a reduced tension. This could affect more spokes, or you could just have the spokes further apart. The best way to make a rim stiffer is to make it taller and more "aero", not to make a rim of the same shape with thicker walls. I've never heard tell of any epidemic of hub failures in people using semi aero rims (real aero being 50mm or more high).
Percy said:Unfortunately I no longer have the rim, or the broken hub. I left it somewhere in Italy after the local bike shop sorted me out with a replacement, so I could get on the road. Should have kept the rim at least and posted it back/kept it to be rebuilt, with hindsight, but I had other things on my mind at the time and was just happy to have a working wheel. Hey ho.
Yeah, I believe the frame takes a maximum of a 42 tyre. I'm wondering where the pay off comes with loss of roll/ride quality and stability/load benefit with the tyres. Do you actually gain that much from switching to a wider tyre beyond, say, 35mm? I'm sort of inclined to go as wide as I can but then I think I'm probably just being paranoid. My load wasn't excessive before but then it wasn't super light either. Are the wider tyres that much more forgiving?
. Phil Wood hubs are really expensive IME.Percy said:Good stuff Willem and Crankarm, thank you both.
If the XT hub has this reputation, it begs the question of what you would use as an alternative? If I'm having a new wheel built with a Sputnik, I might as well consider the hub choice as well, rather than simply returning to the XT.
