Would you reuse rimtape?
Reuse Rim Tape
  • Yes
    Votes: 7 70.0%
  • No
    Votes: 3 30.0%
  • Total voters
    10
This is maybe a daft question but anyway ;-) On Monday I burst a spoke so the lbs is ordering a replacement when it comes is OK to pull back the rim tape at this point, put the new spoke and nipple in and recover or should I cut it off and get new rim tape. I think its a case of too many books! I've read one which says you should always use new rim tape :wacko:
wheres_my_beard
Norwich
[quoteObiWan]Search your feelings...[/quote]
If the current tape has no tears or breaks reuse it. But if it is worn or looking a bit sad, use new, if you feel you have to.
I'm not sure there is a hard and fast rule.
Fiona N
I reckon it depends on the tape - the old stick down cloth stuff I would definitely replace whereas some of the plastic tapes are stretchy enough to pull aside to replace the nipple and then contract back into place.
