migrantwing
Quite simply, can you replace retainer cage and balls with angular contact bearings or not? Is it a straight swap? If a straight swap is not the case, (which I'm believing is not possible) can I use larger or smaller diameter balls compared to what is already in the headset and will it make the headset movement smoother/better etc?
TIA
TIA
