Why aren't toilet bowls coated with teflon?
threebikesmcginty
Corn Fed Hick...
...on the slake
Went to a dunny in Oz and in front of the urinals was a one-way glass looking out over the bar area. I know it was one-way because I checked, afterwards.
Shut Up Legs
Down Under Member
Mmm... just had a brainwave for part of my ideal bicycle: titanium coated with teflon, to make cleaning easier :laugh:. You definitely couldn't call THAT bog-standard :whistle:
Shops like Robert Dyas always used to have spray cans to re-coat a saucepan. Can you get one of these and spray the inside of the loo?
Probably need to check that a non stick saucepan indeed does not get **** stuck to it first.
As a thought. What if you ran some water in the loo so it was wet before you did your business. Would it then not stick?
Brains
Greenwich
loos on aircraft are Teflon coated, and therefore frying pan coloured
