Its not in a tin.....its a machine.If the texture is fine, then surely it is just a case of the wrong shape tin?
Its 'wedge' shaped.Looks perfectly fine to me...
I was thinking that. We had similar when ours was next to the back door, that was often left open. Moved it to a draught free area and it was fine.Bread maker is in a draught or too cold a place.
Same scenario here.I was thinking that. We had similar when ours was next to the back door, that was often left open. Moved it to a draught free area and it was fine.
If it is a small amount of mix in a big tin/pan/whatever you want to call it then it will be low and wide and not reach 'normal' height.Its not in a tin.....its a machine.
Make the medium, cut it in half and freeze the other half.Its 'wedge' shaped.
Should have said......when I make the larger (medium) size its a nice proper shape.
Brown flour is not a great riser, put in a bit more sugar and yeast
