HobbesOnTour
- España
That was me in reference to the brake pads.... until a combination of gravel & off road with heavy rain in Northern Spain and unfamiliar pads meant quickly wearing brake pads and the lack of biggish towns meant no bike shops until it was metal on metal.I think you have to set a limit somewhere, though, and you've just gone beyond mine! I carry spare cables on longer tours as they're small, but I satisfy myself by replacing pads if needed before I leave, so that they've still got enough life in them. If they still wear out, I should spot it early enough to find some because they're not so unusual - except on the hub brakes but they're very unlikely to wear out that fast... cook the hub grease maybe but not wear out pads.
And when my front derailleur cable snapped on my last tour, I confidently pulled out my spare.... to discover I had 3 brake cables..... and no derailleurs!
I only found out the pin was difficult to replace in Verona after an enforced night wild camping at a petrol station during a storm. And that was after having to wait around on a Sunday because nowhere was open! A pin or a new seatpost - either one was responsible for almost 2 days behind schedule.Similarly, I'd only carry a spare seat pin if it's unusual. Otherwise, worst case, I can probably replace it and the clamp with a modern integrated-clamp seatpost if either fail because the diameter is the common 27.2mm.
It's all horses for courses, really. Popular routes well populated with bike shops means we can get away with less tools or spares. More away from it all routes benefit from a little more preparation. My personal approach is to consider the risk/reward.
I'm a great believer in Murphy's Law and plan accordingly
Agreed. I've stripped my bike down and put it back together with what I have on tour. After adding a new front rack, I realised that the hex wrench on my multitool could no longer effectively adjust the brake nut.Related to the excellent "make sure that it can pump to your desired pressures" advice - make sure that any drivers and spanners in your touring toolkit can actually undo the things on your bike. What moves easily in the shed with a long hex key might seem stuck tight with a short flexi-jointed multi-tool.
Oh, if your punture kit is old, check the glue - it can dry out!
