This is another issue I've never had, despite having a pretty heavily loaded Xtracycle at times. What causes a broken spoke?
I've also been fairly cautious about using a spoke key without some kind of tool to tell me what is happening in the wheel when I turn it. How do you tighten spokes without turing the wheel into a Pretzel?
credit card
nothing else.
You're assuming I have money...
In rural Japan (and to some extent rural Germany) credit cards are often not accepted, Japan is especially difficult as they really don't like anything bar Visa and American Express and we have a European Maestro, so I'll have to carry a 'float'.
Toothpaste tube plastic is fantastic.
Sounds like there's an interesting story behind this discovery.
I have a Lezyne one with a knife. Brilliant. Best I have had. Chainsplitter too.
I'll look for that, thanks.
Love the fact that you're planning this on old MTBs!
They're what we use every day, so I figured why change what works? I find that the steel frames and smaller wheels are pretty solid for regular riding in poor conditions.
They are getting some modifications though...
I'd add that you need to ensure you have what you need to re-assemble the bike after the flight (and indeed to disassemble for your return). I'd strongly suggest you set out your tools and go through the full process.
As for a pump, make sure that it can pump to your desired pressures. Nothing worse than a pump that will not get you to the desired pressure....
...Check also your panniers are in good nick as any camping gear you may be bringing.
I always carry spare brake pads and cables. The trip stops dead if brakes fail in the wrong place and a snapped gear cable with a big mountain between you and the next bike shop can mean a long walk.
From my own experience, I always carry a spare saddle pin (holds the saddle in place) after one broke on me in Italy. Spare ones are very hard to find!
If there is any upgrading to be done on the bikes before the tour, look to harmonise the parts if possible - it means less spares required between the 2 of you.
In any case, sitting down at the planning stage and thinking of all the things that can go wrong or break is always far worse than the reality - things will work out! (Well, maybe not if you're travelling across deserts and the like
Dismantling and reassembling will be part of the plan: something will go wrong at some point and require improvisation, I just want to be sure it's something I can improvise, especially as we'll be riding from the ferry port so we'll have to build the bikes there and then or walk 40k
As to pumps, tell me about it: as a child our family pump was terrible and I spent many years riding on saggy tyres.
Thanks for the remioder that I need to get Panniers: Xtracycles don't use them...
I'm a great believer in Murphy's Law and plan accordingly
That's my basic principle as well...
I've got a set of small 'mole' grips with tools inside similar to these,
Oooo. Nice. May fall foul of Japanese knife regulatuions though, and what is the knife for, cutting fresh meat? How would you sharpen the blade?
Basic tool for touring........a rohloff hub
If only...
Cable, spanner, bent nose pliers, cable ties, nuts, bolts, washers, inner tube, a patch of inner tube, tiny sewing kit, gaffer tape, knife, multi-tool, chain breaker, repair kit, tyre levers, toothbrush, lube, pump, a couple of old brake pads, a shoelace a couple of bungees ......... there's probably more!
That's a good starter... I generally carry some good chord when riding, the one that lives in the Bakfiets is rated for 500kg. Possibly overkill there, but still. I'll make sure I have several lengths of thin 25-50kg chord when touring.
Slightly off topic but what is a good cable cutter, for inner or outer cables?
