BentMikey
Rider of Seolferwulf
- South London
The only fact is BM, primary is the default position for you.
Is there any need to make it personal? I'm referring specifically to Cyclecraft here, OK?
I generally do understand the concept. I'm just highly curious as to why you edited a sentence, to say what you wanted it to,when it clearly stated something entirely different.As I said, read the book so that you understand the concept of vehicular cycling and Franklin's definition of 'primary' and 'secondary' - I'm certainly not going to precis the whole book for you.
It'll probably be the best £15.99 you've spent...
This is the quoteMy recollection is that User did put across the intended and actual meaning in the book.
“The primary riding position should be your normal riding position when you can keep up with traffic, when you need to emphasize your presence to traffic ahead, or when you need to prevent following drivers from passing you unsafely.”
“The primary riding position should be your normal riding position,
- when you can keep up with traffic,
- when you need to emphasize your presence to traffic ahead,
- or when you need to prevent following drivers from passing you unsafely.”
He simply did not.I think User put across the meaning correctly. I've just gone and looked in the book. His choice of bolding is not something you need to pick on here.
Just go and read the book before you choose to argue the point further, please?
You aren't meant to ride in primary all of the time. It's a position you take when people shouldn't be overtaking you or if you want to make your self more visible.
Most riding is done in a position labeled as Secondary. Which is nearer to the side of the road.
You've read a book which makes you a qualified expert. I get that entirely
Would you like to attempt to answer the questions?
Is Gaz wrong?
Eh no.Your whole post above would seem like your capitulation on the point that you were wrong to criticise User's post about what is written in Cyclecraft. That is the only thing I'm debating on with you. I'm glad you accept you were mistaken.
I read the sentence as ''normal'' when, when or when, i.e. normal for these conditions, much as T.M.H.N.E.T. does. It's normal that people flap their arms in the air when they fall off the top of skyscrapers.
Which puts me in the awkward position of agreeing with User on his general representation of riding à la Cyclecraft but completely disagreeing with his reading of the sentence in the example that was meant to be proof.
Personally, I find it's completely ''normal'' to be regularly changing position as conditions change, so perhaps I have a problem with the normative power of normal.
Eh no.
