Bike locks and concrete sectional garage
Velochris
I'm looking at a potential new house that comes with a concrete sectional garage.
I would like to keep my bikes in the garage and would use these as security and storage. https://www.hiplok.com/airlok/
Has anyone drilled into sectional pieces ro install something similar? My guess is it will not be possible because it will weaken the sections or fracture them.
Milkfloat
An Peanut
Midlands
I would use a ground anchor, or a chain around the presumably metal roof supports. The airlock is a hell of a lot of money too.
The concrete section will have steel bars running through them I dont think they are more than 50mm in thickness (concrete sections)
a 40mm screw to secure the hiplok will be under size.
Try a ground anchor.
pjd57
Glasgow
Cheap way is to box off a corner with any scrap timber. Couple of feet Square is plenty. Any U shape or square scrap metal section ,sit it in the centre and concrete it in .
Totally secure anchor for very little cost.
Cycleops
Accra, Ghana
Hiplock don't specify what fixing method is used but likely to be a type of expanding bolt. Those concrete sectional garages are pretty old now so might not hold that fixing very well anyway.
I use those have them all round in my garage, it may not stop them, but it will slow them down and that's what they don't like
ianrauk
Tattooed Beat Messiah
Rides Ti2
I have the same predicament as I am moving to a flat with an en block garage.
However rather then drilling into concrete or what ever it's made with I am purchasing an Asgard metal bike shed of which I will bolt to the ground.
Expensive for sure, but worth it methinks.
Milkfloat
An Peanut
Midlands
Won't you have to drill into concrete to do that?
ianrauk
Rides Ti2
What is wrong with a ground anchor in the ground rather than a wall?
I didn't say there was anything wrong.
The walls of the garage are thin concrete and I don't think the neighbours would appreciate me drilling through.
So for me it's a shed anchored to the ground.
