Bleeding Formula disc brakes?
02GF74
Not my bike so don't know model.:sad:
When RH lever is pulled, brakes work ok but then the lever moves out about 1/2 way. It can be flicked out to fully open.:evil:
I suspect due to the total lack of any preventative maintenance:smile:, that the front pads have worn down meaning the pistons are further out thus the brake fluid has dropped, and this is the cause of the lever sticking.
I cannot see any bleed nipple on the caliper nor bleed screw so anyone have this model of brakes and knows how to bleed them?:sad:
Ta.
steve52
I'm back! Yippeee
i had a problem with air , someone said piump the leaver then use an elastic band to hold the leaver back over night it opens the valve and lets the air blead up seems to work
