Jody
Stubborn git
You're far too sensible, go stand in the corner, they don't want answers like that
OK. Skidz are not just for kidz and stopies rule. Back brake only on full if traveling at speed and front brake full if on ice or gravel.
Not on a fixie in UK law (1983 construction and use regs). A front brake only is sufficient if the rear wheel cannot rotate independently of the pedals.
A fixed wheel isn't a brilliant emergency brake, so I am very, very careful to set up and maintain the front brake correctly
Front brake to slow, rear to stop, in an emergency, use both . If it’s icy, the front is liable to let go spectacularly, so use it sparingly.For some time, following advice from I cannot remember whom, I have been using mostly the front brake and the rear brake only when necessary. I am a great anticipator so I have had to brake in a true emergency on only two or three occasions in 10 years, over 75k, of road cycling
Now I have just read that both brakes should be used equally except in icy conditions when maximum front wheel traction is desirable and so rear brake only. What is your technique and why?
Can I assume that rim v disc makes no difference?
But it works for him. Many Moto GP riders never touch the rear brake unless it's wet and they have to brake seriously hard from 200mph +.I use both, favour the front more but use the back a fair bit for subtle reductions in speed
My mate never uses the rear at all, I have tried educating him in the art of braking but it hasn't worked.
I wish I could think quick enough to consider using the front 3x more than the rear in an emergencyI use both brakes reasonably evenly probably 60-40, 55-45 front bias (%).
This becomes approx 75-25 in an emergency situation.
They were more likely to use the back brake to control acceleration in the pre 'traction control' days, helped stop the front wheel coming up too.But it works for him. Many Moto GP riders never touch the rear brake unless it's wet and they have to brake seriously hard from 200mph +.
