Ah, but if you cut it to length AND leave a small tab on the bottom and then bend this out, it will act as a stop.mickle said:The Brompton seat post is flanged at the bottom to stop it pulling through the frame when it's raised. Cutting an inch off will acheive nothing.
dellzeqq said:I've got a telescopic seat post. The top bit is never altered. The bottom bit gets pulled out to the full extent. Works every time
(I realise this only works if you've got long legs, sorry)
)summerdays said:Wouldn't it be even easier for Brompton to make a seat post with ruler like markings on it ... then you would just have to remember a number - I reckon my idea is better than yours!!!!.
summerdays said:Your idea doesn't work if you wear different shoes with different heights of heel!! (You hadn't noticed that flaw had you)
