it occured to me that since it is the flare in the seat post that stops it what you need is a thin walled sleeve to go over the seat post of such a length that your seat post stops at the "top". So you need to work out how much extra post you have, cut the "sleeve" to this size, remove the post, drop the sleeve over it and slot the post back in - however I'm not sure how thin the sleeve would have to be (very I suspect) as it should remain loose on the post and in the frame. Also it may pay to attach it to the bottom of the seat post in some way so that it doesnt' become a permenant and inaccessible part of the frame!
