[QUOTE 3799300, member: 9609"]if it has the 1.6hdi, keep an eye on the injector housings for signs of blow by,  some are known to work a little loose, some of the blow by contaminates the oil in the cam over and turns it to sludge, this sludge blocks the filter to the turbo, very expensive.  - do a search for "1.6hdi turbo problems"
when you are getting it serviced ask them to check they are tight (don't do this job yourself) -  BMW use this engine in one of their small models, I have been told they are checking the tightness of the injectors at service
see this vid on what to look for
[/QUOTE]
It doesn't look to be exactly the same engine, there are a few variants I think but I've just had a look and it all looks OK plus the inspection fella gave the fuel injection system a pass but you've successfully driven up my paranoia levels a bit. I might go and have another look now.
And, perhaps they've changed the design but I can easily change light bulbs, just a cover over the back of the unit.
