Cold wash jerseys - mudstains removal?
mjr
How do you get mudstains (or whatever it is that looks like mud that's been thrown up from the back tyre) out of a white+colour pattern jersey that tells you only to wash it in cold water? Given it a go and it's just not going much. Is the white doomed to be a faded brown dalmatian pattern forever now?
Of course I'd avoid clothes with such care instructions, all else being equal, but this is a special event jersey which, y'know, it would be nice to wear for the actual event and look presentable, at least at the start.
Thanks in advance for any advice from people who have ridden this trail before. :thumbsup:
MiK1138
Glasgow
Problem is if its road muck there will be diesel involved, hopefully someone will have a solution
  • Like
Reactions: mjr
mjr
mjr
Good point. I've just tried the 57th variety of combining search terms and found https://www.cyclechat.net/threads/oil-stain-in-merino-wool-jersey.161003/ which suggests oxi type stain removers for getting oil out of cold-wash merino so I guess if diesel's involved, that may be worth a go. There will be anguish if the (polyester) jersey gets destroyed, though... and probably irritation if the printing fades. I wonder who specs this shoot and if they've ever worn it themselves :crazy:
You probably won't get results in a cold wash. I woukd risk cranking up them temp 10 degrees warmer than recommended on the care label and hope for the best, but don't blame me if your jersey comes out a size smaller.
I only ride in darker clothes now for this reason. Most of my lighter stuff gets ruined by chain oil etc sooner or later. Replace it, or live with it.
400bhp
Bicarb of soda, hand washed (if possible) in very hot water. Leave it to soak then use a brush (or toothbrush) to remove.
Worth a go.
  • Like
Reactions: mjr
classic33
Leg End Member
Not found a solution for cleaning the material entirely of all marks, when it's been thrown up from the road.
Not always just diesel either, following a warm spell, then rain.
Milkfloat
An Peanut
Midlands
Green soap and leaving to soak in cold water with soap power for a day or so.
  • Like
Reactions: mjr
Adam4868
I never really wash in cold water,always go for 30degree wash ? I'd rub the affected area with a stain devil(other brands available !) And hope for the best.
Worst case scenario is your gonna have a skid mark....
Or set of immaculate and come back with one
PaulSB
I know this problem! Last winter on its' first ride out in my brand new and very expensive club jacket got covered in road splash. Made worse by the fact a good friend who turned up without mudguards was responsible!!!! GRRRR
Anyway. Vanish stick, not powder or liquid. Moisten the end of the stick and apply directly to the spots. Leave for five minutes, then moisten the area and rub the fabric against itself (rubbing fabric against fabric eliminates damage). Provided you haven't over wet the area you should see the stain dissolve. Over wetting disguises its presence. Then wash on a 30 degree delicate fabric setting.
I know it sounds a faff and some may think it daft but I do like to keep my kit looking good. In winter I always inspect it carefully after a ride. I believe it helps extend the kit life as well.
  • Like
Reactions: mjr
Buck
Yorkshire
30 degree wash is my go to option. Not too hot but just enough to lift the black line up the back!
If you e allowed the stain to dry on then soak overnight in cold water with a small amount of detergent. Then wash the following day.
  • Like
Reactions: mjr
